Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Distorted image & colors: Hi there I have a sony bravia VPL AW15 with about 140 hours of lamp usage. My problem is that all of a sudden the image is distorted, the letters show in red (3d like effect) and the images show in funky colors like light green/neon. The menu screen though shows fine (the usual white letters against a light blue screen). Any help would be much appreciated
    Scholar:
  • 41 Answers
I'm sorry to say that Jean is off on this one. This is a convergence issue and cannot be fixed with these knobs. The pictures shown look more like a problem with the STK chips (convergence chips). If the convergence went out this bad suddenly and or you cannot fix it with the convergence adjustments on the set, most likely that is the problem. If it moved slightly out over time then most likely you will be able to fix it through the convergence menu on the set. Many things can go wrong with TV sets and you should really do a lot of research before attempting any adjustment and or repair. There are high voltages present and they can reside even when the set is unplugged. I have a posting about the STK chips that may help explain things better.
Posted on Mar 13, 2009
  • Sony Master
  • 3,459 Answers
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem as shown below. Doing so will only make things worse.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Distorted image & colors: Hi there I have a sony - 701cb04.jpg
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions yoDistorted image & colors: Hi there I have a sony - 2c07611.pngnce chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
    Scholar:
  • 29 Answers
Http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
Ken , the poster of that Blog writes........
"The problem is with the convergence via the voltage on the
color ray gun tubes that get out of adjustment.
They are also known as retrace lines."............
This blog covers many makes and models with many
issues solved, just with that one solution
Give it a try, it's FREE and SIMPLE :D
Hope the blog helps you also :)
Jean
Posted on Mar 12, 2009
Sony bravia vpl-aw10 lamp come on runs for 2-3 mins then switches of and lam p cover light flashes 3 time repetedly
Here is a link to the manual. It states you need to replace the lamp because it has reached it end of life an over heating.
https://docs.sony.com/release/VPLAW10.pdf
Jan 28, 2015 | Sony Bravia® VPL-AW10 Projector
Need to reset lamp hours on sony vpl px31
1,Connect the power cord
2,The On/Standy light is red.
3,Press the following keys on the Remote Commander or on the projector in the following order for less than 5 seconds :Reset,left,right,enter.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Jun 29, 2014 | Sony Replacement Lamp for VPL PX21, VPL...
How to open the lamp cover for vpl aw15 sony bravia projector
Lamp cover is located at bottom of projector, loosen its screw and take off lamp cover. Process is also written in user manual page-56 with exploded views. Click Sony Support link to download user manual copy, check page-56 to have better idea.
Thanks.
Dec 14, 2010 | Sony BRAVIA VPL-AW15 LCD Projector
How do i remove my projection lampfrom my sony bravia 60" tv
you jest reverse the projector and you can see the flat screw loos it and you will rise the loker and pul it up ward and do not touch by your finger the lamp if it is 2000 hours working whit the projector you shuold replace it
May 23, 2010 | Sony Bravia® VPL-AW10 Projector
Sony BRAVIA VPL-AW15 LCD Projector power light
i have color bands running through the picture
Jan 17, 2010 | Sony BRAVIA VPL-AW15 LCD Projector
Lamp time resetting
HI
Not sure if its in the handbook but you can download a copy from here
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/VPL-CS5-_E
Feb 21, 2009 | Sony VPL CS5 Multimedia Projector
Reset lamp hours for new bulb
Is it a Sony VPL CS4? Try [Reset], [<-], [->], [Enter] keys
Aug 18, 2007 | Philips UGO X-Lite Impact Multimedia...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
274 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
