Code 123 is a problem with the throttle position sensor circuit. Code 335 is a problem with the crank position sensor circuit. And code 446 is for a EVAP control valve problem. These components would need to be tested to find out if they are faulty.
PO335 crank shaft postion circuit "A" circuit malfunction This sensor is mounted on the left side of the engine block,Near the flywheel. If you replace this because its a code let me know if it worked and if you are getting more than 35 mph.
po843 is a hydraulic pressure valve in the transmission,that will have to be replaced.The code po335 is crankshaft position sensor a circuit malfunction.The sensor could be at fault here.
