Question about Fuji FinePix 2800 Zoom Digital Camera
LCD monitor does not work
My Digital Camera FinePix2800Zoom LCD monitor does not work. when turn the the power on, EVF is working, but when I switch to LCD by EVF/LCD button, there is nothing happened, Lcd monitor has no response at all
call someday help me
  • 57 Answers
SOURCE: Fuji FX700 Digital Camera Brightness problem
hello suresh, i think there si some problem with 'f', i suppose it not works to check it out try to change 'f' and take some picture with different 'f' then chk the result if they differs, it means 'f' is working. If problem still remain as it is, it is serious... then we can doubt on ccd. it both the way you have to take your camera to fuji shop. ohhh yes as you said you bought the camera in january this year, I hope you have warranty, if so do take it to Fuji shop only. good luck...
Posted on Aug 04, 2006
SOURCE: Won't stay turned on
Since mine was only a day or two old, I took it back to the store and got it replaced. Since then, it's been fine. Hope you have the same option.
Posted on Sep 01, 2007
SOURCE: Fuji S5000 Digital Camera--White EVF/LCD Screen
i was told by fuji it is the ccd or cmos sensor effectively the eye of the camera it is faulty and needs replacement fuji said it would cost £90 to replace as the newer model of the fuji is only 145 i opted to buy a new camera so i bought i differant brand and am very happy with my dmc tz3
Posted on May 29, 2008
  • 244 Answers
SOURCE: CAn veiw old picture but the evf/lcd screen is black?
Your shutter is probably stuck closed over the lens inside. Have a look in to your cameras lens and see if you can see the inner lens or just the shutter closed over it.
Will require servicing
Posted on Aug 16, 2009
dlundmark
  • 797 Answers
SOURCE: snowy lcd screen and the eye view is also snowy
Test the camera by taking a picture and saving to the memory card. Then download it from the card to the computer and view it. If it is clear, the problem is in the playback system or the LCD.
Posted on Apr 12, 2010
How can I fix the button that turns on the EVF and turns off the screen? It isn't working.
sir,
I don't understand your question!! how can we use EVF for this model in which it is not fixed from the company, the tilting type LCD is very clear and user friendly in this model.
some old models comes with EVF there may be a small switch beside the EVF. and in some models comes the switching options in the setting menu. if your model is like that you try it in the S-menu.
Jan 10, 2016 | Sony Cyber-shot DSC-HX1 Digital Camera
LCD Screen doesn't work when it is clicked in (screen facing up) it only shows up on the eyehole. I tried hitting the Display button so many times yet it doesn't work.
A Camera Labs review of this camera, November 2008, states, "If the screen is folded back on itself, the DISP button only switches between the two EVF modes." (EVF = Electronic View Finder.) i.e. it is not affecting the screen at all.
On my Canon 60D with a similar folding screen the same appears to be the case but, if I fold back the screen while it is functioning it works OK.
Also, I noticed that pressing several other buttons on the back of the camera effects changes to the screen. Might be worth trying these on your camera.
May 19, 2011 | Canon PowerShot SX10 IS Digital Camera
My s5000 screen is all white in record mode. It breifly had a picture then when I pushed the shutter it went white again????
Does the EVF work? The small view finder above the LCD screen. You can switch to it using the EVF/LCD button on the right side above the main display. If it is okay then you'll likely need a replacement LCD.
Jan 04, 2010 | Fuji FinePix S5000 Digital Camera
I cannot see through my viewfinder to take a picture, but can take pictures on the LCD monitor on my DMC-FZ50 digital camera. Joan
There is most likely a setting in the camera's menus so that you can switch between live view and the eyepiece. Search around, or check your manual.
Jul 07, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
Blank screen
Sounds like you accidentally pressed the DISP (Display) button on the back of your camera. This manually turns the screen on and off in picture taking mode to save battery power. You could then use the optical viewfinder in its place. To turn it back on, just the DISP button one more time.
Jul 07, 2009 | Canon PowerShot SD600 Digital Camera
Camera Screen does not show any picture
Are you sure that you have the EVF/LCD button is on LCD?
Jan 02, 2009 | Kodak EasyShare CX7300 Digital Camera
Fuji Finepix S700
does the LCD monitor work when taking a picture? if not press the evf/lcd button to toggle between the viewfinder and the LCD screen
Sep 11, 2008 | Fuji FinePix S700 Digital Camera
Help! Won't turn on
Fuji suggests; "If the digital camera will not turn on, run through the "Checklist" given below. If this does not solve the problem, take the camera, the batteries, and the AC Power Adapter to an authorized FUJIFILM service center for testing and repairs. [Checklist] 1. The direction of your battery might be wrong. Confirm it and put it again. 2. Load new or fully charged batteries. 3. The battery terminals may be dirty in a way that cannot be seen (fingerprints, etc.). Wipe the terminals clean with a soft cloth. 4. Press the Power button again firmly." Cleaning the battery contacts sounds worth a try. Fuji also say; "Please use only alkaline batteries or Ni-MH rechargeable batteries with Fujifilm digital cameras Please note that instruction manuals provided with Fujifilm digital cameras recommend that only alkaline batteries or Ni-MH rechargeable batteries are used with those digital cameras which require AA or AAA type batteries. If other types of batteries are used together with an AC adaptor, this may result in the rare occurrence of the battery overheating. Please do not use batteries other than those recommended in our instruction manuals." Check that the type of battery is correct Did you buy the camera new? is it still under warranty? Here is the link to the support page for the s7000 including manuals, repair centre details etc; http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportBrowse.jsp?prodcat=616757&sscucatid=664272&sscucatid=664271 or direct to the manual; http://www.fujifilmusa.com/JSP/fuji/epartners/bin/S7000Manual.pdf Apart from contacting Fuji for service, the only suggestion I could find in the manual was that the battery cover may not be closing fully. Worth checking. Hope this helps :)
Jul 01, 2007 | Fuji FinePix S7000 Digital Camera
Even when I immediately switch power source (AC adapter or External Battery Pack) right after the low-battery icon started to blink, the camera operation is still locked.
In cases where the blinking low-battery icon appears indicating insufficient power, wait approximately 8 seconds until the LCD monitor display and the EVF become blank. Then switch to another power source or replace with fresh batteries.
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Fuji FinePix 2800 Zoom Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
