Question about HTC Touch Diamond Smartphone
Touch screen froze
My htc touch screen diamond froze and i have looked for some answers
but i cant find the hard or the soft reset in my settings can anyone help please
    Problem Solver:
  • 16 Answers
Take the back off it and down in the corner youll see a small red button press this with stylus tip and phone will restart
Posted on Mar 04, 2009
WHEN I RESET MY HTC DIAMOND TOUCH PHONEIT'S REQUIRE PASSWORD WHICH IS I FORGOT.
Perform a hard reset by holding the talk and answer buttons and then inserting the stylus in the reset switch hole. This will erase EVERYTHING on the phone, including the lock. Once again, the phone will be like brand new... EVERYTHING WILL BE ERASED.
~KenjiFox
Jan 07, 2011 | HTC Touch Cell Phone (Unlocked) - Soft...
Hi my htc touch diamond restarts randomly few times a day. can anyone help
try updating your software to 1.93 rom, i was having the same issues when i was on 1.37 and my partner was on 1.35 updated and not had the issue since!
update site - http://www.htc.com/www/supportdownload.aspx?p_id=133&cat=2&dl_id=2
also if that doesnt work try doing a soft and/or hard reset -
Performing a soft reset
Perform a soft (normal) reset to clear all active program memory and shut down all active programs. This is useful when your device is running slower than normal, or a program is not performing properly. If a soft reset is performed when programs are running, unsaved work is lost.
To perform a soft reset
1. Pull out the stylus, then remove the back cover.
2. Use the stylus tip to press the RESET button (red) located at the opening of the stylus bay. Your device restarts and displays the Home screen.
HTC Touch Diamond 2 hard reset
Performing a hard reset
If a normal reset does not solve a system problem, you can perform a hard (full) reset. After a hard reset, the device is restored to its default settings-the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your device, and only Windows Mobile® software and other pre-installed programs will remain.
Warning! Your device will be set back to factory default settings. Make sure that any additional installed programs and/or user data have been backed up before you perform a hard reset.
Important If Encrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset, or updating the operating system. Otherwise you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card.
To perform a Diamond 2 hard reset
1. With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
3. Release the VOLUME UP and VOLUME DOWN buttons.
4. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Dec 29, 2010 | HTC Touch Diamond Smartphone
I have htc touch Diamond lcd is not responding with the touch i have tried soft boot and hard reboot both. Please help
you should use heat, put ure phone in a towel & ontop of a fin heater for 15min then it wil work again for so 2days. when problem comes again, do it again.
Jun 27, 2010 | HTC Touch Diamond Smartphone
Touch screen froze on my windows mobile
when u use ur phone, close ur every application one by one
do it n tell me, on my email id nebula1984too@gmail.com
Feb 05, 2010 | HTC Touch Diamond Smartphone
My touch screen froze, so I did a soft reset. This didn't work. So I did a hard reset. All seemed to be going to plan until the 'Align screen' appears. I align the screen as instructed but instead of going...
Whenever you do the alignment touch the spot on the screen with the stylus and hold the stylus on the mark until it moves to the next corner.... this may work
Nov 28, 2009 | HTC Touch HD Smartphone
My touch diamon2 screen just stoped respondin 2 touch.
htc touch diamond help for change languages deutsch to english
Jul 23, 2009 | HTC Touch Diamond Smartphone
I can't use my HTC Touch Diamond screen.
do hard reset, you will find it in user manual
Jun 22, 2009 | HTC Touch Diamond Smartphone
Hard reset for a HTC Touch Diamond
To perform a hard reset
1. Pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press the
Clear Storage
You can also use Clear Storage to reset your device back to factory default settings and/or format the internal storage.
1. On the Home screen, slide to the Settings tab and then tap All
Settings.
2. On the System tab, tap Clear Storage.
3. In the drop-down menu, select whether to Clear Storage only,
Format internal storage only, or Clear storage and format internal storage.
4. Enter “1234” and then tap Yes.
Sep 14, 2008 | HTC Touch Diamond Smartphone
HTC Touch Diamond Smartphone Logo
255 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
