Question about Pioneer DVR-640H DVD Recorder/HDD Recorder
My Pioneer DVD-636D shows FLASH SIG
On the main menu screen and doesn't do anything. Disc won't eject, motor doesn't run etc.
Can anyone tell me what the cause and solution is ?
4 Suggested Answers
Nic61
  • 1073 Answers
SOURCE: Need service manual for Pioneer XV HTD5
http://www.service.pioneer-eur.com/peeservice/InstrManuals.nsf/0/817C627E26301ED841256BE300511FA3/$File/XRB3016_XV-HTD50.pdf
The manaula as asked
Good luck
Nic
RATE me pls:)
Posted on Mar 17, 2009
SOURCE: tray lock on pioneer
press and hold stop button on the front apnel on ur dvd palyer ur palyer will resetting
Posted on Jan 27, 2010
ekcnoel
  • 998 Answers
SOURCE: dear sir, i am
try to clean first the optical lens with a cotton bubs just wipe it gently dont use force you might mis align the lens if still not working check the spindle motor.
Posted on Oct 15, 2010
Hey my mac won't eject a disc. i have tried a lot of stuff and nothing happened. when i restart it the disk spins and doesn't sound stuck and when i used disk utility it said there was an error...
Resolution Tip: Make sure the CD or DVD disc is not in use. Quit all applications that are using files on the disc.
  1. Press the Media Eject key at the top-right corner of the keyboard.
  2. If that doesn't work, drag the disc's icon to the Trash.
  3. If that doesn't work, restart the computer, then hold down the mouse button or trackpad button while the computer is starting up, until the disc is ejected.
    To restart, choose Restart from the Apple menu.
Aug 16, 2011 | Computers & Internet
The dvd starts for a moment and the ejects
Hello
The sled motor of your dvd mechanism has damaged. Sled motor is one which spins the DVD inside as it has been loaded. If this motror does not work, that is, it has been stopeed, the disc won't spin inside the machanism, and your systems main control IC will detect this situationan; will give commat to the mechanism to eject the disc. That is happenig now with your DVD player. Replace that motor with an identical one both in size and number. Its number will be printed on its body. You can see and detect its size. OK.
Jun 29, 2011 | Televison & Video
Eject mechanism failure on cdj 400 ''E 9101''
did you find the motor and belt for ejection mechanism? try to replace that belt.
Apr 06, 2010 | Pioneer CDJ-200 CD Player
Tray lock on pioneer
Jan 26, 2010 | Pioneer DVR-225-S Pure Cinema Home DVD...
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
My screen
It is telling you that, depending on the rear-view camera that is attached, the image MAY appear reversed. If the unit is going into this screen on it's own, go to the main menu screen where you would choose DVD, RADIO, AUX, etc... and press Rear View. It should beep (but not change). That is it.
Jan 20, 2009 | Pioneer AVH-P4000DVD Monitor
Some buttons don't work
Pioneer AVIC-D1 Touch Screen Recalibration
If your pioneer AVIC car navigation unit does not register your touches or the wrong button is “pressed”, you need to re-calibrate your screen’s digitizer.
1-Hold the Eject button down until the face of the unit drops all the way
2-Using a pen hold down the reset button (just above the joystick) and the navigation disc eject simultaneously.
3-Release the reset button.
4-Release the dvd eject button next. The display will read “press reset”
5-Push the joystick up two times.
6-Push the joystick down twice.
7-Press the joystick in.
8-The service menu will appear after a short pause. You can navigate the service menu using the joystick.
9-Chose the first menu option and press in on the joystick.
10-Trace the screen with a stylus.
11-"P.ADJ" is the back button
12-Chose the second menu item in order to calibrate the touch screen. Use a stylus again and tap the "+" sign on the screen. (You may have to touch slightly off center if the digitizer is damaged. In which case things will still be off but it will be much better.)
Jul 27, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Pioneer DVR-640H DVD Recorder/HDD Recorder Logo
89 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
