Question about Toshiba Satellite A60 Notebook
Problems laptop is broken.now it is no power on
  • My reply is May 11, 2010
    Are you sure your AC adaptor working?
    I'm assuming your battery no longer has any power left in it?
  • 201 Answers
First is the ac adapter hard to tell if its working or not
even if green light is on, it could be the end that plugs into laptop
next is the dc jack , take a toothpick or something
and touch the pin inside the jack where you plug the adapter
if this moves just a bit, the pin is broke , a new dc jack is 5 bucks on ebay or more, but youll have to take apart to install new jack
Posted on Jul 21, 2009
Hi when plug in my ac adapter into lenovo x61 the tablet will not turn on i try it on other computer and it will on what happen?
LOL, sounds like your tablet has seen it's better days. See why HP got out of the Tablet business? They are nothing but trouble.
Apr 08, 2012 | Lenovo Tablets & eReaders
I have XPS M1530 DELL Laptop. DC JACK(power charging port has broken from mother with a very small piece of mother board)....I had tried to call customer care ..he told you should change the motherboard...
If this motherboard is a multi-layer motherboard then it is impossible to repair.
You can try to repair the motherboard by glueing the broken piece onto the motherboard with epoxy glue. Then identify the broken power circuit tracks between both parts of the circuit board, and then solder wires across these tracks or to the closest solder connections to re-establish the electrical connections on the motherboard.
If this does not fix the problem then most likely it is a multi-layer motherboard and you cannot bridge the internal connection inside the motherboard.
Jun 22, 2011 | Dell XPS M1530 Laptop
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
I bought new universal adapter for asus laptop and it charges batery just when laptop is turned off
Problem description: The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause: 1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution: 1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Reference: http://www.chargerbuy.com/blog/battery-charges-only-when-laptop-turned-off/
ASUS laptop AC Adapter
Jan 25, 2011 | Computers & Internet
How do I switch to normal power when the battery is running out please. It is a Medion Laptop. The battery warning light flashes and then the laptop warns 'switch to power' but I can't find out how to. It...
This might be an indication of a problem related to either the power adapter, the power cord, or the power receptacle in the laptop.
Please refer to the following article for detailed diagnosis & a fix:
http://www.fixya.com/support/r6395191-troubleshooting_laptop_power_failures_ac
Dec 21, 2010 | Computers & Internet
Powerjack is loose when plugging in charger.no power,no lights battery can not be charged.
In order to fix this problem, you will have to fully disassemble your laptop to get access to the motherboard & the power jack. If the power jack is not broken but only loose, you can re-solder it to the motherboard. Otherwise, you will need to buy a replacement power jack (usually less than US$ 10), de-solder the broken power jack, & then solder in the new one.
When this is done, re-assemble back your laptop.
Nov 27, 2010 | Acer Aspire One PC Notebook
I've had my laptop for two years without any problems. I turned my laptop off, like normal, with no problems last night. This morning theres no lights, nothing, its completely dead and wont turn on.
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 15, 2010 | Computers & Internet
Labtop wont start up
Hi I am a laptop technician, and it sounds like you have a power problem.
Try removing the main battery and starting the laptop on the mains cable only. If the laptop starts fine then you probably have a problem with either the battery or the power board in the laptop.
If the laptop doesn't start when doing this, remove the mains power lead from the laptop and put the main battery back on the laptop. Try starting the laptop off the main battery only and if the laptop starts normally then you most likely have a broken/loose socket that the power lead plugs into in the back of the laptop (a very common problem) or the power board in the laptop is faulty. If the laptop doesn't start or goes off very shortly after pressing the power button it could just be that the battery is flat as a broken power socket on the laptop often stops the main battery from charging.
I hope this helps.
Jan 03, 2009 | Acer Aspire 5315 Notebook
Laptop doesn't switch on
U remove backside battery and connect power connection.Switch on ur laptop power button and check it.whether it is battery problem or ur laptop problem.
Thanks
Feb 29, 2008 | Computers & Internet
Toshiba Satellite A60 Notebook Logo
136 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
