Question about LG KG110 Cellular Phone
HOW TO REMOVE THE SIMLOCK OF LG KG110
MY LG KG110 HANDSET LOCKED WITH A PARTI CULAR OPERATOR(NETWORK) HOW TO UNLOCK IT AS I CAN USE ANY SIM?
  • 2 more comments
  • shivkant Mar 09, 2009
    hi iam kaushal pareek my problem is simlock of lg kg 110
  • vasu889 Mar 21, 2009
    i have same problem pls send solution.
  • Anonymous Mar 31, 2009
    lg kg110 set i had it is bounded to airtel network .is there any way to unlock that my imei no is "354701013021857"
  • jagdesh939 May 04, 2009
    1. IMEI number. 35269101200082400
  • 3 Answers
Lg kg110 set i had it is bounded to airtel network .is there any way to unlock that my imei no is
354701017794558 00
Posted on May 22, 2009
**** :p lg **** %)
Posted on Jun 11, 2009
Go to the service center
Posted on May 03, 2009
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
Simlock sgh j700
You can remove the sim lock error from your phone using unlock code.You can get such codes from your Network service provider or any third party online vendors like ClassiUunlocking.com specify your country,Network name to which it is locked,IMEI number of your phone.
Jan 16, 2014 | Huawei Cell Phones
Sim card valid invalid
"Invalid sim" means that your phone is locked to parti cular Network.To solve this problem you need to unlock your phone. You can unlock your Nokia X6 16GB phone from network lock using unlock code. Unlock code is the best and safest way to unlock phone. You can get the unlock code for your phone from your Network service provider or any third party online vendors like MobileUnlockSolutions.com here you need to specify your country, Network name to which it is locked, IMEI number of your phone. Then they deliver unlock code to you through mail with unlocking instructions. By using this you can unlock your phone easily.
Sep 03, 2013 | Nokia X6 16GB Cell Phone
LG ISO800 unblock simlock
All you need is an IMEI unlock code from an LG UNLOCK CODE website. Once you are provided with the LG ISO800 unlock code, your phone should be 100% SIM LOCK free.
Feb 01, 2011 | LG KG800 Cellular Phone
LG KG110 LOCKED ON AIRTEL NETWORK WANT TO UNLOCK THE PHONE imei: 352691013122775
IMEI : 352691013122775
NCK : 83925105
With accepted SIM or Test card, type 2945#*5101# > Menu 555 > Network > Deactivate > and use the generated NCK code to unlock the phone.
Oct 07, 2009 | LG KG110 Cellular Phone
Unlock my LG KG110 mobile phone.
http://www.foneszone.co.uk/unlock/how_to/LG/KG110.php
Apr 28, 2009 | LG KG110 Cellular Phone
Send me a sim unlock code for lg kg110 handset
1) Type 2945#*5101#
2) GOTO Menu 555 >>>> Network >>>> Unlock >>>> NCK
3) Enter the Code 24545833
Restart ur fone and ur fone is unlock hope so it works for u
Feb 26, 2009 | LG KG110 Cellular Phone
Unlock kg110 airtel network
SIR,
I TRY KG110 AIRTEL PROSES CODE 2945#*5110# BUT BUT NET WORK& UNLOCK OPTION DONOT SHOW ,
SO REQUEST SOLVEB MY PROBLEM
May 23, 2008 | LG KG800 Cellular Phone
Forgot my lock code
remove the sim and enter *2767*3855# then wait for 1 minute your phone gone restart him self then your phone is free
Apr 05, 2008 | Cell Phones
Unlock code
i have kg 110 handset i forget security code pls help me imei no is 354701013552679
Dec 02, 2007 | Cell Phones
LG KG110 Cellular Phone Logo
579 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
