Question about Toshiba Satellite A60 Notebook
Boot from usb
I can't boot from usb2. I have toshiba A60 and bios 1.8.
In my bios there is not this option.
Thank you
  • lucareale200 Mar 08, 2009
    Thanks but I know this.
    I can't boot from usb ubuntu pre-installed in my key.
    I don't know why.
    Novelist:
  • 148 Answers
Sounds like the boot order menu is what you have. Set the boot order menu to try other devices before the hard drive. (Example: CD/DVD drive, floppy; if present, USB devices, hard drive). You should have a default key for accessing the boot menu (usually f11 or f12). Hit this key and choose the USB option. Make sure the device you want to boot to is already connected before you turn on the laptop.
Posted on Mar 02, 2009
  • Robert Kasik
    Robert Kasik Sep 28, 2013
    USB is not option
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
Toshiba a60 bios
Hi ahshan,
You need to enter the BIOS settings, enable USB boot, then disable all other booting devices, such as hard drive and network boot. This should force your PC to boot from your external DVD ROM.
Best wishes,
Graeme.
Jan 05, 2014 | Computers & Internet
Usb boot drive using bios
You may need to enable USB boot function in the BIOS or change the boot order. In some cases the USB boot function has to be forced from boot priority in the BIOS.
Or goto the boot menu when you first turn the PC on there should be an option to use USB Boot assuming the option is enabled in the BIOS already.
Nov 22, 2013 | Toshiba Satellite C655-S5125
Need to update bios toshiba satellite c660,using ubuntu live dvd, will not boot hard drive, all normal recovery options used up
Hi There,
There are currently no easy ways to update a bios through linux at all - including live cd's. Your best bet is to make a bios update USB stick (or floppy depending on the age of the computer)
Here's a link to those instructions:
http://www.biosflash.com/e/bios-boot-usb-stick.htm
Alternatively, speaking from my own experience with a similar situation, you can take the hard drive out, use it in place of the usb stick, boot from it, update your bios, and go from there.
Jun 06, 2012 | Toshiba satellite c660
No operating system found can't boot from usb there is no boot from usb option
Did you try pressing F8 key at boot up?
  • 1
    Turn on your laptop and look at the first screen that comes up as soon as it is on. This screen will tell you "Press x key to enter setup", replacing "x" with the actual BIOS access key. It's usually "Del" or "F2" on Toshiba systems.
  • 2
    Press the key firmly and quickly before the screen goes away. If you do not react quickly enough, you will miss the window of opportunity to enter the BIOS. On Toshiba systems, this window of opportunity is somewhere between two to five seconds.
  • 3
    Navigate your BIOS configuration screen to the "Boot" tab. It is usually just before "Exit."
  • 4
    As the first boot device, select "USB," or "USB HDD." If you have a "USB ZIP" option, you might be able to boot from it, so select that if you have no other choice.
  • 5
    Press the button for "Save and Exit" in your BIOS. The correct button is usually F10.
  • Read more: How Do I Get My Toshiba to Boot From a USB? ' eHow.com http://www.ehow.com/how_5970005_do-toshiba-boot-usb_.html#ixzz1hrx9qZ3j
    Dec 28, 2011 | Toshiba Computers & Internet
    It does not read even if a bootable cd is put. It gets stuck at checking cd rom. It goes to a blue scree - mountable boot error How can I restart it with an Os
    1.Go to bios(pressf2/f10)
    2.select main option
    3 change SATA MODE and change to IDE
    4.preeF10 and save
    5.then start your installation
    more help please vote me and rate it
    Sep 03, 2011 | Toshiba Satellite A60 Notebook
    How did i boot my toshiba satlilit pro
    Here is a solution for your problem.Please follow the below steps to boot your laptop.
    1. First of all insert the CD from which you want to boot your laptop. 2. Shut down your system. 3. Press the power and then start it again and press the "C" key to boot from the CD.
    If this method doesn't work, you can try pressing F2 or F12 at startup and selecting the CD drive from the list of options.
    If neither method works, hold the "Esc" key while restarting the computer and press F1 when prompted to access the BIOS. From there, you can change the boot order so that the computer attempts to boot from the CD before any other devices.
    This will surely help you out.
    Thanks you. Have a good day.
    Aug 10, 2011 | Toshiba Satellite A60 Notebook
    PLEASE I CAN NOT MAKE THE BOOT TOSHIBA SATELLITE A60-S1561
    sign in to bios setup, and then load bios setup to default setting
    please rate my answer
    Dec 06, 2010 | Toshiba Satellite A60 Notebook
    I want to boot from usb flash drive. how can i do ?
    Hi
    Thank you for your query
    Please try the following
    1) Switch on PC
    2) Press F12, del or the ESC key to enter setup
    3) Go to advanced options and then choose boot options
    4) In boot options choose USB peripheral to be set as first boot device
    5) Save and exit from the BIOS screen
    As the PC restarts make sure the USB flash drive is plugged into the PC
    I hope this has been useful
    Mar 12, 2010 | Biostar M7VKA Motherboard
    I have an Acer AOA 150 can't boot from usb
    some bios setup don't have usb boot setting.pls check your bios first if there is USB enable.
    May 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
    Toshiba Satellite A60 Notebook Logo
    3,107 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
