Question about Williams 1403622 Gas Compact Heater
Williams gas heater stays on only for 5 to 7 minutes.
This is a 10 year old Williams gas heater that I turned on today for the first time. It stays on beautifully for 5 minutes then the whole thing, including the pilot shuts off. What is the problem?
  • Williams Expert
  • 252 Answers
Venting problem probably!
Posted on Mar 12, 2009
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
Installed new wall heater and thermostat and pilot is on but heater will not come on?
What about thermostat wire? What ya got 2 wires right? Touch them together she supposed to ignite the flames then after a few minutes the fan kicks in on fan models. You got the knob on the gas valve turned to the "ON" position?
Nov 07, 2011 | Williams (5009622) Ceramic Gas Wall...
Heater turns on and off randomly. Mostly the heater stays on for only 5 to 10 minutes. Had the thermostat changed 5 times by reputable heater man who also installed the wall cozy unit 4 years ago. One...
hi there
could have a faulty gas valve which may let in to much gas.extra load from the stove may be correcting this.
to much gas /too rich a mixture can affect internal temperatures causing thermostats to fail.
does the stove burn a nice strong bright blue flame?.
hope this helps the mystery
Dec 19, 2010 | Cozy (W352E) Heater
How do you turn the pilot light back on? This is an older model, probably about 10 years old or so.
Move the gas valve knob to the PILOT position and press down on the knob. You will be pressing down on a spring loaded safety magnet. Now light the pilot and keep holding down the knob till the thermocouple gets hot enough to produce electrical current and hold that spring loaded magnet in. This is your safety device. If the heat gets too hot the furnace has a fuse in line with that magnet.
When the pilot stays lit by itself without you having to hold down the button then advance the knob to the ON position. Then go to the wall thermostat and turn on the heater.
HOW IT WORKS: WILLIAMS WALL HEATER
Nov 11, 2010 | Williams 6508732 Gas Heater
Hot water heater is natural gas type gas is staying on all the time burning even when water is hot it continues to burn. Not hot water tank is over 10 years old should I try to repair or just replace???
The thermostat is what is out of calibration...this is built into the gas valve. Unfortunately the part cost almost what a new tank does. My opinion is to replace.....today gas valve....another 8 years the tank...
May 09, 2010 | Heating & Cooling
Greenhouse Heater pilot light will not stay lit
replace the thermocouple. it is a small copper tube that screws into the gas valve and goes to the pilot assembly. a good haedware store that sells heaters will have one. they come in various lengths 18"-48".
Nov 30, 2009 | Heating & Cooling
The heater will not stay lit.
i have to start my heater manually. whats bi start it the controller works its when the heater hits its tempature it will turn off thats good, but when i re-start it with the control it wont start. i have to do it manually remove the cover on the heater and push a buttom on top. the pilot is always on?
Jan 31, 2009 | Williams 1403622 Gas Compact Heater
Pilot will not light
The Pilot indicator will appear to line up with the arrow on the base, and even push in as though allowing gas to flow, but if it is just 1mm out of alignment, no gas will flow. So the solution is to move the valve in the Pilot mode slightly in one direction or the other to see if/when gas flows.
Nov 06, 2008 | Williams 1403622 Gas Compact Heater
Williams 1403622 Gas Compact Heater Logo
377 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
