Question about Lenovo IdeaPad Y510 Notebook
Laptop's touchpad not working
I have Lenovo Laptop Y500 4EQ.My child had suddenly removed it's battery in laptop ON condition.One small plastic point of Laptop's adopter broke up.I had put one paper in battery side.Laptop is running ,only while AC on and touch pad is not working.In system ,Device manager showing Device working properly.External USB mouse working now.What i have to do? Please advice me for the same.
  • Gautam Shah Mar 06, 2009
    Thank You very much.As per your advise my laptop's touch pad started working ( Pressing Fn+ Esc ).
  • 479 Answers
Please remove the external mouse and press Fn+ESC simultaneously the issue should be resolved.
Thanks.
Posted on Mar 05, 2009
I have a brand new leneova G580 series laptop .. the touch pad is not working properaly . it selects the whole web page without any command given .. scrole very slow .. checked all settings .. but not working properly
Pls sugest
Posted on Jul 09, 2012
I am using Lenovo Y450, recently I had a an unexpected problem "BOOTMGR is missing" and just fixed it by installing a new windows, but then the touchpad is no more working.
Can anyone please give me advise how to fix it?
Thank you!
Chuc
Posted on Jun 24, 2010
Touchpad and some keys problem
Your problem is two parts. One part concerns the touchpad and that is due to the touchpad hardware connections coming loose. The sticky key however is due to some sticky liquid seeping into the keyboard at one point in time. Maybe the laptop got exposed to a sugary beverage spill that made the keys sticky. Clean underneath you should be fine, but try not to remove the keys as you clean them because the braces that hold the keys to the keyboard base sometimes break.
Jan 16, 2014 | Lenovo G580 Laptop
Remove the biose password lenovo x201
I always recommend popping out the CMOS battery and then putting it back in. This resets all of the settings in the BIOS including the password. In the case of a laptop it can be a bit of work to open it, locate the battery and perform this but it is much less risky than uses the software that is available to crack the BIOS password and then remove it.
This site gives some useful software options for resetting the BIOS password:
http://www.tech-faq.com/reset-bios-password.html
Otherwise this is a diagram of the inside of the laptop once you remove the screws from the underside, remove the keyboard and touchpad:
http://support.lenovo.com/en_US/product-and-parts/detail.page?LegacyDocID=MIGR-71436
Dec 09, 2012 | IBM Lenovo ThinkPad X201 Notebook
How can i fix my not working touch pad?
The information provided is somewhat limited, however, here are a few things to consider.
1.) Check for a touchpad button located immediately above the touchpad itself. Some laptops have this and some don't. If your laptop has this, try pressing it once since it is the ON/OFF button for the touchpad.
2.) It's possible you're experiencing a settings issue. Rather than trying to weed out the specific issue, it would be much easier to do a system restore and revert your system settings back to when the touchpad worked. Goto Start/All Programs (or just Programs)/Accessories/System Tools/System Restore. You want to choose a System Restore date that is BEFORE your issue started. System Restore can take up to 15-20 minutes and should not be interrupted. Just set your oven timer for 20 min and come back after it dings to test your touchpad.
3.) You could have a driver issue. You'll want to check Device Manager for this. In Windows XP, click on Start, RIGHT-click on My Computer, click on Properties, click on the Hardware tab, click on the Device Manager button. In Vista, click Start, RIGHT-click Computer, click Properties, click Device Manager (the link in the upper-left corner of the System Properties window). If you see any yellow question marks or exclamation points anywhere in this list, it's likely your touchpad driver needs reinstalled. Check your manufacturers website for the latest driver.
4.) If none of the above work, you may need to replace the touchpad (or just use a USB mouse).
I hope that helps and best of luck!
Sep 21, 2011 | Compaq (153515-001) Touch Pad
My Lenovo Y510 laptop touchpad suddenly starts moving on it own. Not working properly. What to do?
Uninstall the driver for the touchpad, right click my computer and click manage. Than reinstall, you may want a mouse while doing this. If the problems continues, run windows update and check the optional updates for any updates for the touchpad.
Jul 18, 2011 | Computers & Internet
Unfreeze a cursor on Lenovo laptop
hi! just a tip in most cases this works. try to do power drain, try to turn off the computer make sure that it is completely turned off, remove the battery and the ac adapter and anything that is plugged on to your computer. press and hold the power button for 15 seconds. try to put the battery back and the ac adapter as well, try to power it on. if still doesnt work try to uninstall and re install the touchpad driver for your lenovo laptop. hope this would help! goodluck!
May 26, 2010 | Toshiba Satellite A135-S4527 Notebook
Touchpad not working properly when the power cord is switched on
First uninstall the touchpad driver in add/remove programs, reboot the system and see if the touchpad works better (Some functions may be lost like scrolling, but this is just a test)
Next go to support.dell.com, download the latest system BIOS and touchpad driver, install them and reboot, see if issue is resolved.
Aug 09, 2009 | Dell Inspiron 1525 Laptop Jet Black
The touchpad on my gericom laptop has stopped
simple solution, turn off all power to laptop,(remove power cable) then removethe battery,replace the battery, power up,the laptop will reboot your touchpad drive, and it will be as normal,I have a Gericom 1580 xl+ which this fault appears fairly often, this method always worked for me lordy
Jul 11, 2009 | Computers & Internet
Touchpad & lower 'mouse' buttons do not work
There is a button on the laptop which re-enables the touchpad. It's either next to the touchpad, or you must hold down the Fn button and press one of the function keys at the top.
Jul 07, 2009 | Lenovo ThinkPad R60 with Wireless Wide...
Laptop lenovo 4152 38q
Your touchpad is very sensitive. Be sure to keep your fingers away from it when typing. I have the same problem with my Toshiba laptop--I decided that unless I was in a travelling situation, I would use a small wireless mouse. I just disabled the touchpad.
Jan 19, 2009 | Lenovo 3000 Y410 Laptop
Hello
go here and download the touchpad driver and install it
that should solve your problem.
Oct 15, 2008 | Computers & Internet
Lenovo IdeaPad Y510 Notebook Logo
2,810 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
