Question about MSI K8MM-V Motherboard
Using headfones while having rear ports for speakers
Hi Im trying to figure out how to use the front case ports for headfones while still having the rear port for speakers. I have tried to configure through the Control Panel - Sounds and Audio but it doesn't make no difference even though I tell the SPDIF to be the rear speakers port cna someone tell me if it is possible to do what I think should be simple to do??
My MOBO is MSI K8MM-V (MS-7142 v1)
Im sure last year this was working like this, but then I reformatted and cant get it happening again could it be I need to reinstall the driver again??
PS: I will try to do the driver re-install and post back if I can get it going this way or not later...
  • 86 Answers
You can insert audio driver cd in your cd-rom .then instal the driver.
Posted on Mar 01, 2009
  • 78 Answers
This MotherBoard has a special software that comes with it to handle all the sound related stuff. If you install this program it should be easy to control the sound then.
My speaker jack broke off inside my audio input in the back of the computer. I want to use the thermaltake case's front usb and audio out/mic in jacks, but they don't seem to get power or work. My drivers...
> Have you removed the broken jack from the rear end of the pc ?
> Are you trying to use the audio ports on the front panel ?
> if you are trying to use the audio port on the front panel you will first need to remove the piece of the broken jack stuck in the rear port - cos you can take an audio out line either from the front OR the rear any one
Oct 22, 2013 | Thermaltake Mid-Tower VL10001W2Z Element G...
1991 ea ford stereo wiring colours ? i know the speakers,im left with green/yellow,blue/white,black,
Hi there:The Falcon EA (Australian) also called Granada/Scorpion (Europe) or Taurus (America), check this informacion...
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Orange/Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4" Speakers
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Red
Car Audio Rear Speakers Size: 9" x 9"
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Light Green
Left Rear Speaker Negative Wire (-): Dark Blue/Orange
Right Rear Speaker Positive Wire (+): Pink/Light Blue
Right Rear Speaker Negative Wire (-): Light Brown/Red
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Nov 09, 2012 | Cars & Trucks
Im trying to install a sony xplod radio in my 1995 Nissan Maxima. im using scorsche wiring harness A/B. i did all necessary installation procedures and the radio works but im not getting any sound out of...
Maxima Wiring Diagram
1995-97 Nissan Maxima Stereo Wiring Constant 12V+ Pink/Blue Switched 12V+ Blue/Black Ground Vehicle Chassis Illumination Red/Blue Dimmer Red/Orange Antenna Trigger Black/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Diagram for any aftermarket head unit
Black: ground
Red: switched 12volt (accessory)
Yellow: 12v Constant
Orange: Illumination (Dimmer)
Blue: Remote
White & White/Black: +/- Front Left
Gray & Gray/Black: +/- Front Right
Green & Green/Black: +/- Rear Left
Purple & Purple/Black: +/- Rear Right
Dec 23, 2010 | Car Audio & Video
Need the output wiring diagram for a AUDIOVOX 93-im-ETX radio
Wiring diagram for Audiovox 93-IM-ETX
Figured it out by taking radio lid off and following the leads:
Black/white--ground (-)
Green/white--battery (+, that is, always on)
Orange/white--ignition/ACC switched power
White--left front +
Red--Left rear +
Blue--right front +
Yellow--right rear +
Light Green--negative for front speakers
Purple-negative for rear speakers
Sep 28, 2010 | Audiovox Car Audio & Video
What is speaker size front and rear in 2002 GMC crew cab?
Fronts are 6.5, rear passenger doors are 5.1/4, and the very rear im still trying to figure out...
Jun 29, 2009 | 2002 GMC Yukon Denali
Onkyo TX-SR576 7.1 Rear Channels problem
Have the same amp and speakers, had some trouble getting the imput signals sorted from the HDMI input as im using a PC with HDMI output from the mother board and Windows Media Centre. havent tryed using the mic set up yet.
Did you resolve the issue? have you tried the 7.1 outputs
Jun 21, 2009 | Onkyo Audio Players & Recorders
Sound problem
Hi ozlion, there are a set of pins dedicated for front sound & mic operations. The fact that your front is loacated on the side of the case is irrelevant. If there was a difference in the sound between the rear jacks as opposed to the side jacks there may be an adjustment one could try but this is not the case. Both side & rear are not putting out through all your speakers.
This indicates a problem with the integrated sound chip or your speakers are defective. Suggest you swap your speakers with (a known good set) of speakers. If the good set of speakers do the same than the motherboards integrated sound chip is bad.
A work around would be to add a PCI sound card to your system. That's only if your board is out of warranty.
(So hate giving out bad news).
ozlion, if you have more questions feel free to ask.
Good Luck!
Mar 24, 2008 | EliteGroup 661GX/800-M (661GX800M7)...
MSI K8MM-V Motherboard Logo
54 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
