Question about Panasonic Televison & Video
Can't get tv to change past 9 with remote
Let's say I try to go to channel 23 with my remote, my tv on recognizes the first number and goes to channel 2, then channel 3.
  • 75 Answers
You probley need to go into the menue and manually enter or add the channels to the scan program of the tv. The numbers are some times pin when they arenot in scan and turn green or yellow when they are in the scan pattern.
Posted on Mar 01, 2009
I've had my Sony Bravia 52EX701 for over 3 years. We have two remote controls. The main one we use is through our older Bose Home Theater System to control the TV, etc. The Bravia remote is also activ
Maybe there has been a disconnect with the TV recognizing the code of the remotes? Or, maybe you pressed a button on the remote that will not allow it to change the channels. I've done this in the past where I accidentally pressed, say the TV or DVD button, and when I turned the TV on and tried to tune in channels, the TV would not respond. Pressing the cable button (but that is on my remote) returned the remote to its ability to change the channels. You will just have to do trial n' error.
Nov 30, 2014 | Sony Televison & Video
Codes for Magnavox TV wlDVD to work with ATT U-verse remote
Four digit universal remote codes for Magnavox TV are:
0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
Setup Proceedings.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out.
Jul 06, 2012 | Philips Magnavox REM-350 Remote Control
I tried auto programming my tv but I can't go past channel 69. All other tvs go up to at least 99. When I try to manually program 99, the remote will only input a 9.
There are only a possible 48 channels available in the UHF bands IV and V; 21 - 68. Some Continental TV's still use band III; 1 - 20
Are you sure you are not getting confused by programme numbers which can go up to 99 and AU etc.
Jan 04, 2011 | Panasonic CT-27E13 27" TV
I programed my time warner cable remote to my philips magnavox tv everything works pretty much but i cant change the channel what am i doing wrong?
Possibly try using a different code or if you programmed the remote by using the search feature, then keep searching past the first code that it recognizes and see if it will recognize another code.
Aug 09, 2010 | Televison & Video
Remote only advances by one channel.
The button on the remote next to 0 and below 9 has to be depressed to _ _ before you select any 2 digit channels. I had the same problem and accidently figured it out. Hope it helps. TC
Jul 13, 2008 | Memorex MT2206 TV
Can I use another remote?
I have the same model TV, also without a remote. I found a Philips universal remote model CL019 at Big Lots and it works just fine. However, for some reason when I tried to program in the channels it would only program in up to channel 23, and then after about 15 seconds add channel 60. Can anyone help?
Jan 19, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
Tv channels
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
Nov 11, 2007 | Samsung CXJ1352 13 in. TV/VCR Combo
My SONY TV remote control doesn't do what it should
problem due to dry soldering remote microprocecer
May 21, 2007 | Sony RM-Y135 Remote Control
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
