SOURCE: Speedo, turn signals, brake lights, horn stopped working. All else is fine.
Gap your plugs to 38 thou. Check all your bulbs (one burned out will affect the rest) Take a look at all your fuses and make sure they are all ok. Otherwise you are probably looking at a wiring short which will require trouble shooting of the elctrical system. Buy your self a service manual for your bike, this will help you a lot.
SOURCE: '06 Harley Davidson FXDI35 Speedometer and Accessories Don't Work
Check for coroson on all the conectors.
SOURCE: The tail light, turn signals, speedometer and
Yes it could be a fuse, they are located under the panel on the left side I think if not under the other panel
SOURCE: My speedometer on my 2000 FLHTC is stuck at 60mph,
It could well be a fuse problem .Contact you local harley agent and ask where is the fuse box located for this bike ,
SOURCE: 2003 road king speedometer stop working no signal
Sometimes when I ride my 2002 RK 150 miles or more, the speedo quits, the signals won't cancel, and the idle drops to barely running. Anyone have any ideas?
