Question about Dryers
Stop Hitachi Ceiling Fan Oscillating
How do I stop a fan like this http://www.hitachi-hk.com.hk/Products/index.aspx?nodeID=417&langno=1&UID=1209&detail=1
oscillating?
  • 3 Answers
SOURCE: my oscillating fan has stopped oscillating how can
This is my 3rd fan in the last two years I have bought. This time I thought by buying an expensive fan won't give any problems, but it is the same story.
Fan worked for couple of days, then it won't start again. I figured out from the noise it was making that it is due to friction. So I put some oil, then it started working, but it worked for a day only.
It is the regular fan, not the tower. Hope someone knows the answer for this.
Posted on Aug 02, 2009
SOURCE: LASKO fan problem
Check for a loose wire in the wiring harness
Posted on Sep 04, 2008
hiltonjug
  • 612 Answers
SOURCE: Dryer heats for a bit then stops.
Looking in the wrong place. i see this 3 to 4 times a week. you have a bad motor. Motor will continue to run if the gas does not light. Just like it runs on air only. The motor stops due to internal switch that keeps it from catching on fire. Sorry someone put you on the wrong track but you will need to replace the motor.
Please rate this solution if helpful.
Posted on Aug 25, 2009
  • 88 Answers
SOURCE: Whirlpool Imperial dryer cyclic thermostate
there is a easyer way to check this put unit back together...put or had on back were vent blows hot exhaust air out...you should feel it get very very hot...then start to cool down..were you could put your had on the vent....if not replaced fixed tsat....please call if need more help..mike..843-384-8474...
Posted on Apr 03, 2010
seanpwright
  • 2030 Answers
SOURCE: Assembly instructions for ClimateKeeper Oscillating Pedestal Fan
need to know what brand and model nu,mber you have
Posted on May 16, 2010
I have a swan vornado oscillating table fan. I
Stop loving it. The new fans won't even last a few years.
Oct 14, 2014 | Dryers
I have a Holmes HAS1650 stand up fan and I need to know how to get it to quit rotating.
Not sure what you mean by "stop rotating"
I assume you mean to stop oscillating. There should be a knob on top of the motor housing that you push down to oscillate and pull up to stop oscillating.
If you mean to stop the blades from spinning there should be a fan speed control knob on the top of the motor housing that you turn to "O" to stop the fan.
Here is an instruction manual for a similar fan...
http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-holmes-products-Site/Sites-holmes-products-Library/default/v1405596036669/documents/instruction-manuals/HASF1515R_HASF1516R-UC_11EM1.pdf
Jul 18, 2014 | Dryers
I have a Minka Aire ceiling fan. It is two years old. It has a remote. The fan will not stop! We took off the blades to stop the air (it is dead winter here) but the whole light just spins and wobbles. Not...
One simple thing to check is to make sure the DIP switches in the remote and the receiver match up. There should be a set of small switches (usually inside the battery cover) that are set for a sequence. The sequence on the receiver must be the same. Otherwise, you probably have a bad remote or receiver.
Feb 26, 2010 | Minka Concept II Flush 44 Ceiling Fan by...
Ceiling fan wont move much air even on high speed
shut off fan, wait until it comes to a complete stop. switch button on base to other position. turn on
Sep 10, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Squeak in aloha breeze tower fan model 05538
If the model is equipped with a fan, and the noise occurs even when not oscillating it must be a fan/blower motor. If it is a squeak. A squeal could be an electical component going bad which is always bad. I would definitely take some bottom drawer tools , ie. screwdrivers and WD-40 and oil that squeaking motor. Being a fan it goes through alot of air pollutants. That tends to build up on the shaft and can work its way into the bearing seal. Good luck.
Jun 28, 2009 | Tower Aloha Breeze Fan
My ceiling fan wont stop shaking
sound like the fan is unbalanced , go to HOME DEPOT or any hardware store and purchase a pack of weights , these are small weights with self adhesive on them, to BALANCE IT start with one blade at the time , with the pack of weights it should include a square black horseshoe type to clip on the fan blade , this black clip is to let you know where to put a small weight, OK , so clip on at the middle of 1rst blade , start fan at high speed , if it shakes less , put on a small weight , do the same with the rest of fan blades , until it stop shaking , hope this helpful , AJ
May 18, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
Oscillating
Hi - You can download the manual by clicking the link underlined in blue below:
Lasko
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 05, 2008 | Lasko 1820 Stand (Pedestal) Fan
Dryers Logo
200 people viewed this question
Top Dryers Experts
