The fault is on the motor control board, which is on the bottom left when looking from the back of the machine. There's a good chance that one on the connectors will have over-heated and burned the track. I fixed ours by utilising an unused connector on the board and swapping the pins in the connector.
SOURCE: Washer not completing cycle
I HAD THE SAME PROBLEM ON A 4 MONTH OLD MACHINE AND I CALLED A SERVICE PERSON. HE SAID THAT I CAN THROW IT AWAY. THIS IS A PROBLEM THAT NOBODY CAN FIX.
SOURCE: Ariston Washing machine A1636 - Flashing lights
always reset your machine ;turn your dial to the end of the cycle [ the dot] it should flash 3 times quickly, then turn off the machine and on again. then start washing again ...hopefully..worth a try.
SOURCE: ariston Margherita 1324
blocked filter. unblock filter under lower front panel( right hand side )
unsrew lid over pump clean filter
turn machine off for 5 mins
SOURCE: my ariston a1237 washing machine keeps throwing
http://www.applianceaid.com/beltdrive-change.html
click this link directly to reset the belt again.
thanks.
SOURCE: Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
