Question about PaceMaster Aerobics Pro Plus Walking Belt
ERROR CODE 30 ON MY PACEMASTER PRO PLUS
THE MOTOR WILL NOT COME UP TO SPEED ALSO STOP AND START.
    Top Expert:
  • PaceMaster Master
  • 12,223 Answers
DescriptionErrors 30 through 33 all indicate the loss of communications or erratic communications betweenthe microprocessors in the upper PCA and the lower PCA. The trouble shooting procedures forall of the are essentially the same. Error 30 is defined as upper PCA not receiving from lowerPCA. Error 31 is defined as faulty data received from lower PCA. Error 32 is defined as lowerPCA not receiving from upper PCA. Error 33 is defined as faulty data received from upper PCAPossible Causes1. An upper PCA to lower PCA interconnect cable is bad.2. The interconnect cable at the upper PCA was mistakenly plugged into the CSAFE connector.3. A 5.17 EFX equipped with version 1.01 upper and lower software.4. A 5.17 with mismatched upper and lower software.5. A defective lower PCA.6. A defective upper PCA.Possible Remedies1. Substitute a know good interconnect cable between the upper and lower PCAs to determineif the interconnect cable is defective.2. Remove the interconnect cable from the CSAFE connector and insert it in the correct upperPCA connector.3. Replace the 5.17 upper and lower software with the most current software versions.4. If only one of the upper or lower software is version 1.01, replace the version 1.01 softwarewith the most current version of software.5. Substitute a known good lower PCA to determine if the lower PCA is defective.6. Substitute a known good upper PCA determine if the upper PCAs defective.Proceed according and fix it. God bless you
Posted on Mar 23, 2013
Pacemaster pro plus
Usually dirt build up. Open cover and clean mecha
Jul 08, 2014 | Exercise & Fitness
Pacemaster Pro Plus treadmill popping fuse
You need to replace the walking belt. Don't use the machine until you've replaced that.
May 22, 2017 | Exercise & Fitness
I have a Pacemaster Gold treadmill that will not hold elevation. I have no error codes. It will go to the proper elevation and then immediately start descending. If I change the elevation setting it will...
Run the utility software calibration for easy diagnostic, and fix it.
Go to HOOD open the cover motor and follow the steps indicated. or your owner manual.
God bless you
Sep 30, 2013 | PaceMaster Gold Elite Treadmill Upper...
Pacemaster treadmill err 133
I just fixed the same 133 error, it's about the communication between motor module and upper panel. There is an 8 wires cable, uses standard RJ45 connectors. In my case, one of the RJ45 connector to motor module is poorly done by the manufacture, so the connection is not reliable, I re-do the connector, problem fixed.
Apr 15, 2013 | Treadmill Doctor Pacemaster Platinum...
Pacemaster treadmill will not start, no lights, nothing.
Is there a spot on the control board you can check for out going power? You might have a bad board. You can visually inspect your board for anything that looks burnt or one component that looks swolen or loose. Poor solder joints are a common problem with treadmills because of the constsant movement.
Feb 18, 2013 | PaceMaster Aerobics Pro Plus Walking Belt
Pacemaster pro plus error code 20
If you wish to get some details About treadmill Error codes ; check the site linked here. Pull up older posts almost all treadmills are listed . Surf the site with patience. http://electro-medical.blogspot.com/
Dec 24, 2012 | Exercise & Fitness
Getting a dead sensor reading on pacemaster pro plus treadmill
OPEN MOTOR SHROUD INSPECT THE COMPARTMENT ON THIS INSTANT I BELIEVE THAT THE SENSOR IS AT THE OPPOSITE END OF THE MOTOR THE LEADS GO INTO MOTOR CONTROL BOARD I WOULD FIRST UNPLUG AND PLUG THE CONNECTOR THIS WOULD CLEAN ANY OXIDATION OFF. IF NOT YOU SHOULD BE ABLE TO DO THE REPAIR
Mar 02, 2010 | Exercise & Fitness
PaceMaster Aerobics Pro Plus Walking Belt Logo
872 people viewed this question
Top PaceMaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Tom Chichester
ray gallant
Are you a PaceMaster Exercise and Fitnes Expert? Answer questions, earn points and help others
