Why is there no driver included with installation software
SOURCE: epsonperfection 1670 fluorescent light replacement
Here's what Epson tech support sent me about this problem:
Thank you for contacting the Epson Connection.
The error you are receiving may be from the twain driver but also the
Scanner itself. Please have your scanner checked with a technician. You
may
find the neares one by clicking on the link below.
http://www.epson.ca/cgi-bin/ceStore/support/SupportIndex.jsp?BV_UseBVCookie=yes
If you require further assistance with this particular issue, please
ensure
all of our previous correspondence is contained in your reply, so we
can
better track the history of this issue.
If you have a different issue, please submit another E-form via our
website
(http://www.epson.com), and we will respond in a timely manner. Thank
you
again for contacting Epson.
Patrick H
Epson Connection
SOURCE: Need installing software
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=mbqAVwjIQ4AGxtvKmU002FNke9QZuBiximpW
use this link and you will find all drivers and manual etc
I hope this helps
cheers
SOURCE: Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
SOURCE: Epson perfection application not working on G5 10.5.8
hi there. you actually downloaded the right driver :
try this Run Photoshop in Rosetta mode; Epson Scan 2.77A only runs in Rosetta mode.
Follow the steps below to run Photoshop in Rosetta mode:
