Hello, Working on SD-V291 dvd/vcr combo. Will not read the dvd, but after a few minutes saids incorrect disc. It will play CD's ok. It came in with the dvd tray out of place and hitting the optic pickup unit.All looks ok. Bad pickup????? Thanks, Karl Kvicala
-   Up until a few days ago the SD-V291 worked fine. Now DVDs that I watched a couple of days ago I get feed back, "Reading Disc", then "No Disc", tried a DVD laser DVD cleaner, same results.
Looper 007-   Guest
Best Solution
posted on Aug 02, 2007
Melissa - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Most likely the pickup is defective, or something is out of alignment. The tollerances are very close on these, and if something is just a few mills out, it will not work properly.
Jerry G.
Was this helpful?
Yes
No
Solution #2
M0nica L - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
P.S.
Some players might not be initialized in this sense at all - or the information may only exist somewhere in Japan.
hi! its easy! the DVD u r playing is not in ur region format. i mean it might be PAL .... but if u live in US, Canada, or anywhere in America, it should be NTSC.... download convertxtodvd from the website of its own and then add ur avi or any format video.. then go to settings, and in settings go to DVD specifications... then scroll down the format box and select ur region format... NTSC is AMERICA, ASIA and PAL is EUROPE. after selected, go back to the main screen, and select convert.. now this may take a big time process.. maybe 2 hours as it is converting bad quality avi format to excellent quality dvd format , after that , when done, burn the dvd and play on ur DVD VCR player!!!! i had the same prob too!! i read the dvd manual for it!!!
pssssst.... i wasted over 12 DVDs to fix my prob :0......well thts it!! try it!!! ask me anyquestions u have.. my email id is: ishaan_m2902@yahoo.co.in .......!!!!!!!! :)
Was this helpful?
Yes
No
Solution #4
Janice - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Varies from one manufacturer to the next. A Toshiba authorized servicer may be able to get you this info - or perhaps a Google search if you're lucky. Some newer players can have their firmware loaded / upgraded using a cd-rom burned with that specific firmware and updating program.
Mark Z.
Was this helpful?
Yes
No
Solution #5
kioner - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
I have seen some Pioneers etc that need to be re-initialized. This could be your issue.
Mark Z.
Was this helpful?
Yes
No
Solution #6
Gary10 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
What kind of DVD disc are you trying to play? That unit is not compatible with any dvd-rw or dvd-ram disc and also will not play out of region discs.
David
Was this helpful?
Yes
No
Popular Solutions for Toshiba SD-V291 DVD Player /
My toshiba dvd player works for 20 min then breaks up and stops. If I try again after several hrs...
(More)
My toshiba dvd player works for 20 min then breaks up and stops. If I try again after several hrs the dvd plays the previously problem section OK but for only another 20 min.
The machine is completely dead like it isn't getting electricity; however the tv is hooked into the...
(More)
The machine is completely dead like it isn't getting electricity; however the tv is hooked into the same power strip and it is fine so something must be wrong with the dvd/vcr player. Any ideas?
