Question about Saeco Odea Giro Plus Coffee Maker
Saeco Giro Plus Bean Grinder Section Inoperative
My Saeco Giro Gran Plus coffee machine will not grind beans. It starts up normally and achieves a green status light. However, when you press the brew button, the machine does not make a grinding sound and the red error status light turns on. I could not find a troubleshooting routine for the grinding assembly. Can you provide troubleshooting solutions to correct this problem?
I am facing the same problem. Please let me know if you can fix it. Thanks.
Posted on Nov 24, 2009
  • 5 Answers
Is there any solution to this? Is it the same problem as described here? http://www.fixya.com/support/t23269484-grind_red_lights_come
Posted on Feb 01, 2014
How do i change grinder setting while its running
I don't believe you can. There is a switch that turns off the grinder if you remove the lid to the bean hopper. The grinder adjustment is under that lid...so, unless you bypass the switch in the lid (which can be done) you cannot get access to the grinder adjustment.
-doc
Jun 26, 2014 | Saeco Odea Giro Plus Coffee Maker
My Odea Giro stops working when entering the brew pump cycle. When I run it without coffee it runs fine. When I add coffee it stops after the grind cycle. I have replaced the microswitches and cleaned the...
I had a similar problem
Mine was caused by an "oily" type of coffee beans. Grind was accumulating in the grinder.
I did open the machine and cleaned the grinder physically. At least, try to remove all beans and sucked with a vacuum the interior of the grinder screw.
Good luck
Jun 18, 2014 | Saeco Odea Giro Plus Coffee Maker
Hi i have a Saeco Odea Giro Plus, that was broken ceramic baked klay. after replace new it have a problem with my Saeco Odea Giro. The problem is that the bean grinder doesnt grind (I only hear sound of...
you need to change this part ,which is under the ceramic knife. You will have to open the coffee grinder and take out the knives and change the holder to the lower knife. That's your problem. This is the product code 149198350
Apr 22, 2017 | Saeco Odea-Giro Espresso Machine
Saeco odea does not brew. coffee beans will grind, then coffee maker will start flashing all lights, and ground coffee will spit out without brewing. when i change beans to more oily ones, it works without...
Hi...Keep on grinding until the Auto Dosing System readjust the amount of grind to be in the optimum. Normally it takes 3 to 4 grinds. Whenever we change the type of beans, this condition happens, it is not a problem.
Aug 29, 2011 | Saeco Odea Giro Plus Coffee Maker
The bean grinder doesnt grind, only water comes out
If it is working before, probably the coffee chute is clogged up. You can remove the bean hopper and see where the coffee drop into the brew unit.If the chute is still attached just clean the blockage, if it is broken you will have to remove the grinder and replaced it.
Jan 17, 2010 | Saeco Odea-Giro Espresso Machine
Hi i have a grinder problem with my Saeco Odea Go
Try this remove all the beans using a vac cleaner, then turn to lowest-finest number, then remove screws on grinder lift chamber and turn knob to coarsest setting and reassemble and try machine, remember to adjust grind when machine is grinding.
Sep 10, 2009 | Saeco Odea-Giro Espresso Machine
Hello. I have a saeco vienna superautomatic
This happens due to condensation caused by steam developed at the end of the grinding cycle. Make sure that the grinding chamber is completely cleaned and dried before using the grinder.
  1. Turn the whole bean chamber to the right until it can be lifted off the base. This will allow you to clean the grinding wheel. NOTE: Never use water or liquid for cleaning the lower grinding section of this appliance.
  2. Clean interior recesses with a soft brush (not provided).
  3. Wash the whole bean chamber and lid and the ground coffee chamber and lid in mild detergent and water. These items are only dishwasher safe on the top rack of your dishwasher. Wipe exterior with a damp cloth. Do not immerse mill in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  4. After completely drying, replace whole bean chamber. Important: when replacing whole bean chamber, screw on completely before setting grinding rate. Turn chamber clockwise (as viewed from top), until it will not turn. Fill with whole coffee beans for grinding and replace lid.
  5. Replace ground coffee chamber and lid, making sure it snaps securely into place.
Aug 02, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
My Saeco won't grind the beans
There's moisture in the grinder & it's clogged - just dismantle the grinder & clean it, then ensure you don't splash water into the bean hopper when you fill the water tank.
Mar 29, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Odea Giro Plus Coffee Maker Logo
1,279 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
