Question about Onkyo TX-SR605 Receiver
Compatibility will skw204 power sub work with my txsr605 onkyo receiver
    Scholar:
  • 85 Answers
Yes here is the manual for it.
http://63.148.251.135/redirect_service.cfm?type=own_manuals&file=SKW204_En.pdf
now you will see this picture on page 5
compatibility - 768816d.jpg now where it says 6 this is your line input. Now you will plug in a subwoofer cable to this and on back of your receiver to the subwoofer output. and you now must enable the subwoofer option in the setup menu of receiver i think it would be under speaker configuration.
so the answer is yes it would.
Posted on Mar 01, 2009
  • Chuck Mar 01, 2009
    yes here is the manual for it.
    http://63.148.251.135/redirect_service.c...
    so the answer is yes it will work. sorry for the double post but the picture from manual didnt show up for some reason. but you can still see it from page 5 of the manual using the link i provided. just make sure to enable the subwoofer on the receiver to make it work.
Sub woofer not receiving signal from onkyo HTR520 , bought it in 2007, it works when hooked up to another source. can it be hooked up without using the sub woofer out put on the onkyo
The best thing to try is a factory reset of the Onkyo. The subwoofer out may be stuck off, even if the settings say its on.
hold down the Video 1 and Power on/ Standby buttons. The display should say Clear, then enter standby
turn it on and try the sub again.
since its a powered sub, you're not going to have much of a choice in other outputs without extreme distortion.
also, if that model has two zones, make sure zone 2 is off.
May 05, 2017 | Onkyo Audio Players & Recorders
My receiver is not picking up the subwoofer, there is noise coming from the sub when I'm playing with the conection. The speakers are working and im getting prefect sound from them Please help.....
It would be helpful to know if this is a new problem on working equipment or a new problem on NEW equipment. And if you've flipped through the manual without success.
Of course you KNOW the sub must have its own amp, right?
First, you need to determine if the Onkyo or the unnamed sub is at fault.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR608-Receivers-manual/id/23653ag916/t/2/
At the Onkyo, check to make sure you have run the speaker setup starting on Page 40. If that doesn't work...
Disconnect the subwoofer pre-out at the Onkyo and move it to the VCR Out, tune an FM station and be ready for some real loud subwoofer output if your sub has no volume control of its own. If you can hear the sub, it works and it's back to the Onkyo. If not, the unnamed sub
Apr 09, 2011 | Onkyo TX-SR608 Receiver
I have an Onkyo HT-R8230 receiver and I can not get any sound out of the center channel or the subwoofer. The sub will not even power on. It stays in the standby mode and there is no manual on/off button...
The manual is available at retrevo.com.
If you don't have the center and sub defined in the Onkyo they will never work. See page 20.
If that is all set and you still have problems...
To prove the center speaker works, connect it to one of the front channels.
To prove the sub works, connect it via RCA cable(s) to the Tape Out and play something containing deep bass. You should see it come out of standby and hear something, albeit only the deep bass.
Aug 03, 2010 | Onkyo HTR500 Receiver
Will skw204 power sub work with my txsr605 onkyo
Mar 01, 2009 | Onkyo TX-SR605 Receiver
Is my txsr605 compatible with a dxrd511
Yes it will. Connect it using the ins and outs of one of the "Tape" inputs and it should work very well.
Feb 26, 2009 | Onkyo TX-SR605 Receiver
Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Jan 28, 2009 | Onkyo TX-8511 Receiver
No audio or video with HDMI connedction
AT THE START OF THE SET UP MENU CLICK ON IN/OUT ASSIGN.THEN MONITOR OUT APPERS,THEN HDMI NO,FLICK THIS TO ON.IFF YOU GET PICTURE AND NO SOUND GO TO THE HARDWARE SET UP AND DOWN TO HDMI AND SWITCH AUDIO OFF.
HOPE THIS HELPS.
May 05, 2008 | Onkyo TX-SR605 Receiver
Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
Apr 22, 2008 | Onkyo TX-SR605 Receiver
Subwoofer goes to sleep
The receiver automatic speaker set-up set the sub volume at -12 and since it was not getting any signals from the receiver it was doing what it is supposed to be doing (going to the standby mode). This was troubleshooted by Onkyo tech support on a Sunday. All the best about Onkyo customer support.
Apr 12, 2008 | Audio Players & Recorders
Onkyo TX-SR605 Receiver Logo
155 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
