Question about Kenmore 46462 Front Load Washer
Kenmore he2+Will not go through clean machine cycle
Kenmore he2+,Will not go through clean machine cycle and having error. Possible that some thing stuck inside. How to open machine and remove it?
  • 1 more comment
  • ostrov Mar 09, 2009
    The error means that the washer is not empty and suggests removing clothes from the drum. The problem is that the drum is empty. I called a technician once in the past for the same problem and he fixed the washer by opening the drain pump and removing a very small foreign object from it. Now I have tried to do the same thing, removed the bottom panel, but don't know how to open the pump. Any suggestions?
  • ostrov Mar 10, 2009
    Well, I did it, but there were no foreign objects inside. I have tried the clean cycle after that, but it still finishes with "rL" error. What is the problem?
  • ostrov Mar 12, 2009
    As per the tech manual, "rl" error code means that the washer is not empty and suggests removing clothes from the drum. That is obviously wrong. What is malfunctioning?
    Problem Solver:
  • 17 Answers
Open bottom panel, there should be a tech manual, see what the error message means.
Posted on Mar 07, 2009
  • 1 more comment
  • bacoo Mar 10, 2009
    When you open the bottom panel the pump is right there, just unscrew that cover but be careful, there would be water coming out
  • bacoo Mar 12, 2009
    I will check to see what the error rl means, but in the meantime does the washer go through a normal cycle without any problems? Also if you interrupt the clean cylce chances is that sometimes you can corrupt the ccu.
    Well I presume you did take out all clothing from washer, so what is happening is the motor which has tachometer is sensing you have clothes inside hence you would have to replace the motor.
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Kenmore washer error codes
Appliance Repair Forums
Near top of page click on Thread "HE Error Codes"
Even blonde can do it Quick fix repair for Kenmore He2 front loading...
Search youtube for he2 washer for other help videos
Aug 18, 2014 | Kenmore HE2 Washing Machines
Kenmore he2 plus washerwashing machine turns on but cycle does not engage
The error F21 is a long drain error and usually the drain pump is not working or the filter is clogged. Remove the lower kick plate and clean the filter. Post back your results.
Jun 28, 2013 | Washing Machines
I have a Kenmore washer HE2 plus and F26 is flashing
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
May 14, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus error code F21
F21 Is a slow or long drain.
Things to look for kinked drain hose, Plugged or obstructed drain hose, Possible pump filter screen clogged, Least unlikely is a drain pump failure.
The pump filter screen is the most common it gets plugged with lint, coins, hair etc. It can be cleaned by the owner however is is a very dirty messy job and if you are not very careful you can end up with water everywhere. If you want to attempt it let me know. If there is anything else I can do to help please let me know.
Mar 20, 2010 | Kenmore HE2 Plus Front Load Washer
Error message 5d on kenmore he2 fron load
Hi mankin1,
It is possible that instead of 5d that you have a SD. The SD error is usually form an excess of suds in the washer. In most cases you can run the machine through a couple rinse cycles and clear that right up. If that does not work then you will need to clean out the drain and your pump filter. The filer is located behind the bottom panel and you just unscrew it from the pump. If infact you had a 5D error then I am sorry for misinforming you, I have just never heard of a 5 D and I have been services them for years. I really hope this helped you, good luck. Mike Anderson mca0824@aol.com
Mar 28, 2008 | Kenmore 43142 Front Load Washer
Kenmore 46462 Front Load Washer Logo
157 people viewed this question
Sal De
fordexpert
Robert Rankin
