Question about Radio Shack Radio Communications
I NEED SCHEMATIC OF TRC444 MIC PIN - Radio Shack Radio Communications
    Problem Solver:
  • 9 Answers
Try this.
pin 4 - audio
pin 1 - shield
pin 2 - N/C
pin 5 - receive
pin 3 - transmit
This is a standard TRC microphone wiring
Posted on Mar 07, 2009
I need an FS-1503 mic wiring schematic. It is an 8-pin and I want to convert it to 4-pin. Any tip please?
find the grounds
on 8 pins you have two grounds black wire and copper screens
connect both to a flying wire
you can use a beep test digital meter {2$ type} to find the TX line
white or yellow is usualy audio to the radio from the mic
and thats it
oh yey too find the ground on the radio look up its details
you can use the beep test also to its neg wire {not the case it floats not + or -}
the case is for the screen wires coppers
the black wire is ground on the mic plug only
the white or yellow will be audio to the radio
the orange or blue will be TX enable and gets shorted to the ground black when you press the TX key
so armed with this
good luck and happy festive season....!!!
Nov 27, 2014 | Radio Communications
Schematic radio shack
try googling it. Are you talking about the power plug or the mic plug? the Mic plugs should all be the same.
Sep 02, 2014 | Radio Communications
I have a radio shack trr470 and I bought a cobra CA-76 power mic with a 5 pin conector instead of a 6 pin conecter by mistake .can I use this mic on this radoo .do you know what cooe wires form tje mic go...
according to the schematic I just looked at the mic for this radio is a 5 pin. As long as it is a plug in and not a din you should have no problem connecting it.All you have to do is re-wire it and be on your way.
Jan 18, 2013 | Radio Communications
Configuration settings PIN code
Try Hard Reset your Phone
Here's a hints on how to repair or fix Nokia 5800 XpressMusic Digi Mic Knopfler problem issues.
A guide picture below which I included an schematic diagram shows each every components and line paths for quick test and check up procedures.
Digi Mic Knopfler Pin configuration:
1. L/R - microphone's left and right audio signals groundings
2. CLK - Audio Clock data
3. Data - Digital Microphone data
4. VDD - Power supply voltage
Locate and trace each and every components, line paths and corresponding connection as shown on a picture. The red highlighted components and line paths is for the power supply voltage which came from Power management IC (AVILMAS) Vsim2- approximately 2-3 volts.
Test and check this components and track the supply voltage from C220 to C2170 then through the digi mic knopfler pin 4.
The pink highlighted components and line paths is for Audio Clock data signal, which is came from the Audio Codec IC (Avilmas) then flow across R2201 and R2170 (valued 100ohms each) then to the Digi mic knopfler pin number 2. Check also the C2173 valued 22p Clock filter capacitor for possible damaged.
I included step by step procedures on the images like as follows:
* Check each components and line paths.
* Replace if found open or shorted
* Jumper the line paths if found open or cut
* Check or replace the digi mic knopfler for a quickest step might as possible. ides.jpg
The microphone's digital data signals has also a line paths connected to the front side of the Printed circuit board, check and trace also this line paths which is connected to digi mic knopfler's pin 4
Feb 17, 2011 | Nokia 5800 XpressMusic Smartphone
Does the roger beep come with instructions? It can vary between beep boards.
Typically it gets installed inline with the mic jack.
There is a wire or pin on the board where the tx wire, and the rx wires go.These wires get disconnected from the mic jack, then a wire goes to the tx pin. Then there is an audio wire that gets connected to the audio wire of the mic jack. Then the black wire to ground, and the red wire to switched 12v right off the power switch.
Here is a schematic of the board connected to the mic jack so you know what pin is what.
Again, I would need to know what roger beep board you would like to install.
Feb 22, 2010 | Galaxy Radios DX-33HML 40-Channels Base CB...
Need wiring diagram for trc444 cb radio
Hello. Here is the wiring
PIN 2 - N/C
Mar 11, 2009 | Radio Shack Pro-83 Scanner
Microphone problem
Feb 23, 2009 | Radio Communications
Shure SM2 Headset/Mic wiring
Headset connection: Blue wire to Pin 2, White wire to Pin 1, Yellow wire to Pin 3. Connect Pins 1 & 2.
Microphone connection: Black wire to Pin 3. Red wire to Pin 2. Ground wire to Pin 1.
I am using a male/female 7-pin XLR connector assembly to black box. I am using two 3-pin XLR connectors, one for SM2 microphone function, one for SM2 headset function.
Jan 02, 2009 | Shure SM2 Professional Headset
Radio Communications Logo
247 people viewed this question
Top Radio Shack Radio Communications Experts
Greg Cann
Greg Cann
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
