By LiZzIe - usenet poster
Hi everyone.
I have a problem with Minos, a non-linear programming software programmed in
Fortran. We compiled this program with Compaq Visual Fortran 6.5 on Windows
2000.
When I call Minos many times, I notice that the computer internal clock
accelerates. Is there any Visual Fortran setting that could cause this
effect? I actually study this code, but if someone experienced something
similar, I'd like to know about it.
Regards.
Fran??ois Grondin
Solution #1
posted on Aug 02, 2007
Perkins - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Seems like a question for the developers/maintainers of the library.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
kcw573 - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
^ This is a new one for me.. I can't imagine anything that CVF could be
^ doing that makes a difference here.
^ However, it helps to understand how the clock is handled by the OS.
^ The OS schedules an interrupt every 10 milliseconds (usually), and
^ when this interrupt fires, it adds a preset value to the variable it
^ uses for the system date. It is not actually reading a hardware
^ clock. There is a mechanism to write the date/time back to the
^ hardware clock, but this typically happens only at shutdown or perhaps
^ infrequently while the system is running.
^ I could see the possibility of a highly compute-bound application
^ preventing this interrupt from firing in a timely (!) manner, but the
^ usual effect of that is to make the clock seem slow, not fast.
I have experienced something like this. A very simple stress test
application, written in FORTRAN but making STDCALLs to interact with
imaging devices via TWAIN. Repeated opening and closing of the Data
Source (the software associated with the hardware). One particular
device, the Intel QX3 play microscope, behaved very curiously. On the
first machine I ran the test on, after a few hundred open-close
cycles, the machine had ground to a halt - swapping itself to death,
basically. My log file recorded that the cycle time had suddenly
started to increase dramatically, from around 10 seconds to ultimately
about two and a half minutes before everything finally collapsed in a
heap. Where it got really weird was on the second machine I tried.
This time the log file recorded that the cycle time had stayed rock
solid at around 10 seconds, but the system clock had lost about three
quarters of an hour.
Andy
sparge at globalnet point co point uk
We must be fearless
We must have fearlessness
We must not be fearlessnessless
We must not have fearlessnesslessness
We must be fearlessnesslessnessless
Andy
We must be fearless
Solution #3
Melissa - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I have read in the past that some anti-virus software has had a
side-effect of making the clock run slow or fast - how, I don't know.
I haven't experienced this myself. You may want to see if disabling
your anti-virus software makes a difference here.
Please send Visual Fortran support requests to
Steve Lionel
Software Products Division
Intel Corporation
Nashua, NH
User communities for Intel Fortran and Compaq Visual Fortran:
Solution #4
Hart - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Certainly not deliberately... :) Don't see just how it could interact
unless there's something in there to do usage checking and it mucks up
the setting via a system API call somehow (or your driver code is doing
something similar).
I note you're on CVF 6.5, you might consider the 6.6 downloadable
upgrade, but I think it will not have any bearing on this particular
phenomenon.
something similar).
phenomenon.
Suggest a new solution for this problem
Post a New problem for Intel Play QX3 Monocular Microscope
Email this problem
Email this problem
Can you Help with these Microscopes problems?
Repair Service
Find Microscope Repairman Near You:
