Question about Maxtor 60GB ONETOUCH III MINI-EXT 5400RPM 8MB (R01E060) Hard Drive
Not recognized as a drive, cant read/write.
Hardware is installed .Says working Okey but, I don't see drive letter. Can't read/write ! Tride all USB ports on P4;Win XP.
  • 1,472 Answers
Pathak_heman
If the drive is not showing in My Computer you will need to assign a drive letter to the drive. The link below will show you how to do this.
http://www.fixya.com/support/r4183994-change_drive_letter_in_windows_xp
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Aug 18, 2010
I have Windows XP. I connected the hard drive according to the directions and the first message read USB device not recognized. The second message read Try reconnecting. If windows does not recognize it...
If it is a desktop computer, try connecting to one of the rear USB ports. sometimes drives won't be recognized properly from a secondary USB or HUB. If it's a notebook go into control panel and see if you can find and delete unknown devices in hardware then attach and see if it connects. XP should not need a driver install.
Aug 24, 2010 | Computers & Internet
I've tried to put things on my usb but whenever i put it in a computer they all say that it doesn't recognize the hardware
All Portable HD are Plug and play devises. But sometimes they require softwares. So read your manual for further details.
Think this is helpful !
Aug 11, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
My pc now recognizes the drive as a local drive, but the drive cannot be read. Is it possible to restore the drive without deleting the files on it? They are some extremely important.
There are several things to try:
1) Disconnect all USB devices and restart the computer. Then plug in your external Hard Drive. In some cases, this has worked to enable external devices as there's a conflict between some USB devices. Once working, you can add any other USB devices you have.
2) Since the drive is recognized by XP, right click on it and if you have access to Tools, try to check the volume for errors. It may ask you to reboot and do a scan disk on startup. Sometimes although the computer recognizes the volume, it hasn't sufficient information as to how to access it. Running a scan disk can cure that problem.
3)Re-assign the drive letter; Occasionally XP can't access a path to the external drive; if it assigns a letter, in turn it will gain access
Change Drive Letter
The link above provides step by step instructions to change the drive letter
4) Run Windows Update and install SP3; Service Pack 3 addresses issues with external devices that weren't fixed in either SP1 or SP2
I do hope one of these answers provides a solution to your problem. Please post back with any other questions or just to let me know how you made out. Unfortunately, you have a common problem but no one FIX has been identified by Windows to solve it.
Best of luck!
Greg
Nov 06, 2009 | Western Digital My Book Essential Edition...
Vista stops recognizing external hard drive
This doesn't sound like an OS issue. This appears to be more an issue of the connection to the hard drive. The USB cable likely isn't the culprit, nor the laptop USB inputs. If the drive was ever dropped or the cable gets removed and reattached often to the actual enclosure, you might be looking at a bad port on the enclosure. This isnt a lost cause. You can always buy a hard drive enclosure from newegg and move the drive from the IOMEGA to the new enclosure. You can get a new enclosure for $15. Just because the USB port is bad, it doesnt mean the data is gone and the hard drive cant be used.
Aug 26, 2009 | Iomega 33089 250 GB Hard Drive
Icant see my usb flash drive in my computer
You can try this out:
After powering up your system, and you have plugged the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Flash Drive to be detected automatically.
Hope this helps you out.
Jul 15, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Trying to use a brand new Verbatim usb 500GB portable hard drive
For WindowsXP:
Goto Start> Control Panel>
Select Hardware Tab > Divice Manager
Select the + on Disk drives, and see if you see your USB Verbatim drive listed (if so good, close all thoes windows and goto the next steps) If not stop here.
From the Contorl Panel> Administratinve Tools> Computer mangement>
Under Stoage select Disk Management on the left panel
Look in the Right panel and single click your USB drive in the "Volume" colume.
Know look at the lower panel and make sure the drive states that it is "Online", look at the "Health" Status. And;
Make sure it has been "Partitioned" in the Layout colume. If not right mouse click the drive letter and select "Mark Potiton as Active".
Right mouse click on the USB drive in the Volume colume> select "Change Drive Letter and Paths"
If there is on drive letter assing to it select the Add button, if one is there, select the Change button and assign one to it or change it to a drive letter that is beyound the number of drives you have.
In other works if you have drives C:, D: and E: before you add the USB drive, make it the H: drive.
Exit out.
Now check your drive files.
Jan 21, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
Cant put songs onto my daughters bratz mp3 player
When plugging a USB removable device/storage, you should see an icon named "Safely Remove Hardware" in the system tray (right side of the task bar, near the clock). Left click on it, and you should see a list of removable hardware.
If you can not see the device there, then there is problems with your MP3 player, perhaps the battery is too weak; if this is the case, just leave it a few minutes until the device charged and initializes and recognized by the computer.
If you can see the device, but no drive letter assigned to it, then there is problem assigning drive letter to it.
You can re-arrange the drive letter assignment by entering Computer Management console: right-click on My Computer, then click on Manage.
Choose Disk Management, and assign a drive letter to your device.
Dec 15, 2008 | Jwin MP3 Player
Verbatim 250GB External Hard Disk not recognized by PC
Almost always, when a USB drive doesn't assign a drive letter in MY Computer the issue is a Mapped network drive using the drive letter the USB drive is attempting to use.
With the drive connected, open DISK MANAGEMENT find the USB Drive, right click it and assign it an available drive letter.
Jun 12, 2008 | Computers & Internet
Canon camera downloading
An update from Mccoyb:
I have to take back some of the previous conclusions about the problem being with the Canon Camera. I based conclusion on the belief that I'd previously had the same problems on a different computer. I think that is now incorrect.
Adding to previous comments above:
I pulled the memory card out of my camera and into an SD CardReader. Plugged the cardreader into the USB port where the camera had been. Again, problems. I switched USB ports. Still, problems reading the card reliably just as the camera had done.
I took the same USB cable to another computer. This time, I could access all data flawlessly on BOTH the cardreader the camera. On this computer, no Canon software had been installed, so I used Microsoft's tool (automatically pops up when camera turned on) to copy the pictures to the hard drive.
I'm starting to think my USB drivers on one computer are somehow completely hosed up. So many different hardware USB ports should not simultaneously start failing. In addition, I tried a THUMB DRIVE and it had very slow performance and problems recognizing the drive letter. However, I tried an external 500 GB hard drive, and the drive letter came up without any problems.
Something may have changed with a Microsoft update that caused USB drivers and/or handling of the USB ports to change. Either that, or there is a virus impacting only the USB ports.
Anyhow, I don't believe it's the camera now or the memory cards.
May 07, 2008 | Canon PowerShot SD1000 Digital Camera
Maxtor 60GB ONETOUCH III MINI-EXT 5400RPM 8MB (R01E060) Hard Drive Logo
90 people viewed this question
Top Maxtor Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Rick Arnold
Mark Taylor
Mark Taylor
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
