Question about Canon PIXMA MP460 All-In-One InkJet Printer
Error code: 2,155,0 for scanner
When trying to use scanner the following message appears -
"Cannot communicate with scanner.
Cable may be disconnected or scanner my be turned off. Check status.
Scanner driver will be closed.
Code: 2,155,0"
However the printer & copy functions work perfectly.
  • 46 Answers
SOURCE: scanner error
if you put the installation cd in the drive and then if it autostarts close it down, then go to device manager and the properties of the scanner and update driver let pc search automatically and it should reinstall it and then all should be fine i hope , had the same problem on my all in one device
Posted on Sep 24, 2007
SOURCE: error 21550 pixma mp160
I found a solution for this problem
change your usb cable.
you must use a Anti noise usb cable
it's only solution
Posted on Nov 19, 2007
SOURCE: I cannot get my PIXMA
http://software.canon-europe.com/software/0028481.asp
For any pilgrims lost on the path, and trying to follow the map above, here is a major road not marked
- the actual link here takes you straight there! I couldn't get it from the canon website, I got it by searching for 'scangearmp-common'.
Posted on May 03, 2008
SOURCE: Scan function won't work with Mac OS10.5.5 & Airport
I have a new macbook pro OS 10.5 and installed a new HP L7590 all in one printer. Same problem. Called Apple and they confirmed that they do not have a driver for the Airport Express to allow scanning wireless. Therefore, SOL. If want to scan, then have to unplug from APE and plug into laptop. My solution is to use a USB hub and mount close to desktop so I can easily remove my HP and connect to laptop to scan often (or buy a cheap flatbed). GARY
Posted on Jan 16, 2009
odiebugs
  • 949 Answers
SOURCE: PIXMA Cannon MP 130: Scanner Problem
You said the printer works, but does it work from windows sending it to the printer.
If it does, then there could be a few problems. You should start by looking at you printer under start-printer, you should see the printer and should show your model. I would make sure that the software
you installed for the printer was for the OS you are running Xp,vista and try to reinstall it.
Because of the one error you listed, driver failed. Most times you can just reinstall it again,and when it goes to the folder just have it overwrite the folder. If running vista, turn off UAC when installing drivers.
Then unplug the printer and plug it back in after you restarted the system from the install, and windows will see the printer.
Now maybe someone had the same problem that can give you better advise so just wait. But you can at least shut down your pc, unplug your printer, restart the system,plug in the printer and try it again,and if the problem remains, hopefully someone else posted or try your software install. Hope you get it working.
Posted on Mar 21, 2009
I can print but cannot scann
try to uninstall then reinstall the printer software.
Apr 10, 2014 | Canon PIXMA MX310 All-In-One Printer
Mp navigator 4.3 don't start
On Windows Vista, the following error message may appear while scanning:-
Code: 2,155,0 (or Code: 53,3,0)"
In such a case, close the error message and confirm that the cable is connected and the printer is turned on. And then perform a scan over again after a while.
Oct 29, 2011 | Canon Pixma MX360 Printer
I am trying to scan a document using the Canon PIXMA MG6120 that is connected via wireless LAN to my laptop. I get an error message on the laptop as follows: START OF ERROR...
Your firewall block the communication. You will need to get into your protection software and allow 'full' access of MP Navigator (EXT)
Aug 03, 2011 | Canon PIXMA MX870 Wireless Office...
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    Scanning error - cannot scan error code 2,155,0 ???
    i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
    here is the link : http://www.fixyourownprinter.com/forums/printer/49111
    Thanks
    Sanjieev
    Jan 13, 2009 | Office Equipment & Supplies
    All in One Scanner/Printer problems
    Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
    May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Canon PIXMA  MP460 All-In-One InkJet Printer Logo
    741 people viewed this question
    old marine
    old marine
