Question about Soundstorm 2000W MOSFET 4 Ch Amp w/Remote F4500 Car Audio Amplifier
My amp just stopped making sound
It has been working for a while now and today it just went out for a minute then came back for 10 secs then went out again and wont go back on power is on tho fuses are good
  • Chris Thompson May 11, 2010
    Have you checked your Ground Wire and made sure it has an excellent connection. Also have you made sure that the Hot wire running form your fuse link to the amp has a secure connection. Did you check the fuse in your fuse link?
    Problem Solver:
  • 14 Answers
You mite have blown a speaker that would cause the amp to short and over heat and turn its self off. you also should make sure its not your deck
Posted on Mar 01, 2009
I have a memorex. I am getting sound but no picture. When powered on, the memorex sign shows up but then no picture just sound. Also makes a slight screeching sound for approx 10 sec. when powered on.
I guess the blanket draped over the TV is intended to give it a "timeout". Anyway, you will likely conclude eventually that the internal power supply has failed.
Jan 02, 2014 | Memorex MLT1921 19 in. LCD TV
Resetting 1999 cavalier security system
If it's a factory alarm then you need to get it disabled by the dealer. if it's an installed alarm you need to unplug the brain/ module and your car should run
Feb 25, 2013 | 2001 Chevrolet Cavalier
My TV died & all that remains is the red light of death!
What you see is an indication of some failure inside the board. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Televison & Video
Sanyo dp42740 plasma powers on & alluminates screen, but no pic & no sound. Power cycles its self on/off about every 10 sec.
Try if you have not done so to unplug set and or any box in line being used for a while--plug them back to allow them to try to reboot--a box acting up can cause issues with many sets.
Problem indicates a power supply or main board problem but may not be either.
Jun 07, 2012 | Televison & Video
'91 F150 won't start
I guess there could be debris in the tank - but the fuel filter will catch it and clog up (is that a hint, or what),
Other possible is the ignition coil... the are plastic inside and they dry out and crack inside.... when they are hot - open circuit... When they are cool, closed circuit - working...
so, next time it dies, check for spark. Otherwise, replace the fuel filter (hopefully you have one OUTSIDE the fuel tank).
Let us know - please... -Jim
Oct 22, 2009 | 1985 Ford F150
1992 LEXUS LS400 STALLS WHEN HOT & IDLE SURGING
Sounds like a fuel problem or a clogged catalytic converter. Check your filters for the fuel system. Make sure you can hear the fuel pump kick on. If that doesn't work you need to separate the header from the catalytic converter. Then try to stall it again. Hope this helps.
Jun 12, 2009 | IBM ThinkPad T30 2366 Notebook
LG Window AC Problem
send it back again!
May 03, 2009 | LG Heating & Cooling
Car won' start
Sounds like baD FUEL TO ME.
Jul 29, 2008 | 2002 Pontiac Grand Am
Car sound system. only sub is giving off sound. other 4 speakers dont work at all
Could be bad outputs from the back of your head unit or also could be bad rca cables. Make sure the amp is on and powered.
Dec 13, 2007 | Kicker CompVT CVT654 Car Subwoofer
Soundstorm 2000W MOSFET 4 Ch Amp w/Remote F4500 Car Audio Amplifier Logo
74 people viewed this question
Top Soundstorm Car Audio & Video Experts
Coss
hoyzee1
Are you a Soundstorm Car Audio and Video Expert? Answer questions, earn points and help others
