Cant get air con to work it is a teco air conditioner
It has been working til today, there is a light which says timer and a light which says pre-def both these lights are on and i dont think they were before. no matter what i ask it to do nothing happens. if i turn power off and back on it seems to work for about 30 seconds then these 2 lights come back on and it stops, the remote says R11HG/E-XLM and the air conditioner is a teco, split system, i am renting and have no manual, can anyone help?
Ours did the same. My husband checked the manual and found that the filters were FILTHY! The filter is at the front of the inside unit. If you still have the manual it will show you where. This fixed ours as it was NOT working at all!!
Posted on Jul 28, 2010
  • mattamie Jul 28, 2010
    Just read that you don't have a manual. You can lift up the front of the inside unit. The filter lays on top. It should be transparent. Ours did EXACTLY the same thing. We thought we'd broken it!
  • Ryan Winn
    Ryan Winn Jun 06, 2015
    Up under the main front cover on the top right hand corner is a button called "manual switch" push that in and it will reset the unit. But make sure you pull out all grates/ filters and give them a Vacuum and a dust down then soak in water/ sugar soap solution dry off and towel pat down.
    Problem Solver:
  • 5 Answers
Are the wires on the head in the same spot on the compressor
and is the gas level right if they are low it will not work
Posted on Mar 02, 2009
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
Gree 18000 Btu Air Conditioner , f2 appears on display
F2 is an indoor pipe sensor fault. You will need an air con tech or electrician to do this as the sensor is wired into the indoor board. Gree parts can be a bit difficult to obtain but a similar sized pipe sensor from an LG or Teco unit will work. You may have to "splice" the new sensor onto the existing pipe sensor wiring as the connection to the indoor board will likely be different. Contact LG or Teco for your colsest parts outlet or buy direct from them.
Sep 07, 2013 | Gree 18000 Btu 20 Seer Ductless Mini Split...
How to reset pre-def red light blinking on teco aircon unit
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Air Conditioning Tamarac
Jun 10, 2013 | Heating & Cooling
Teco LS1209Y faults pre-def
How do you take the cover of to get to the filters
Oct 16, 2012 | Heating & Cooling
Cant get heating to work
adjust temp e.g. 39 deg Celsius or high and turn on heat,but first you must turn off air conditioner then select heat rating and turn on a.c.
Jul 05, 2009 | Heating & Cooling
I need operating instructions for a teco air con model LT2424YS
I have an TECO Model 7K34STC, that has the two end bearing & housings missing from the opposite end to the motor.
Could anyone tell me of a parts supplyer in Florida U.S.A.
Please reply to
Peter Lawrence
brin4512@hotmail.com
Jun 28, 2009 | Heating & Cooling
All lights are flashing including Pre Def, Timer, Operation and Auto but air conditioner is not functioning
Not sure the make and model of your equipment you have there but sounds to me like your control board is trying to tell you it is bad.
Jun 12, 2009 | Heating & Cooling
Heating & Cooling Logo
2,043 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
