Add a bigger ground wire or move the ground wire to a new spot (make sure ground is bigger than power wire) or it could be fuse on amp but i think its a ground
1. Hold down "Energy Saving" and "Lighting" buttons simultaneously for 10 seconds (or top left & right buttons). Display panel returns immediately
2. press the Freezer and Ref buttons at the same time for 8 secs and Bam!!!! Bac 2 normal!
3. pressed the power freeze and vacation buttons for about 3 secs and it worked
4. I held the top left and top right soft touch buttons on the screen itself (which I think is the power save and the lighting buttons) and held for about 8 - 10 secs and it reset
Hope it helps. Its in the combination of two buttons pressed simultaneously. Try your luck.
there is usually a soft reset for when these things freeze, go on internet & find what yours is, usually combo of holding down 2 buttons at same time for 10-20 secs.
Edge 205 or 305 often crash, then impossible to power on again.
Here is the way to reset the Garmin edge :
Soft reset : hold mode and lap/reset buttons for 10 seconds Hard reset : device should be powered down, hold start and mode buttons for 3 seconds then pulse press the lap/reset button.
After soft reset, you need to hold start button for up to 10 secs before it starts.
After hard reset, you will loose all your data, including profiles.
Place the key into the #2 position (do not start engine). With the oil remaining light showing on the odometer, press and hold reset post for 10 seconds until it starts blinking, then let go. Press it again for 5 seconds and it should reset back to 100%.
1 : call on ur num from any other phone. if rings going means its software is malfunctioning . wait till the battery went all out ( u can check it while calling in 1 hour interval when u getting a powered off / not responding msg.
get it charge n it ll be ok ..
if ur using 3.1.2 firmware then i ll strongly recommand to reinstall the firmware as it might give u the same issue in future
2 : if ur phone is not responding n ur confirm its off.. press both home and head button for 9 sec then leave the home button n again press it for 10 sec n leave the head button after wards.. ur phone ll go into recovery mode. if still same issue.. contact the vendor to get the phone issue checked
Yes, the bars on armature comutator are lifting, usually caused by heat. Only thing to do is replace armature and brushes, but best to also have field coil tested for shorts before buying new armature.
Check your Hot and Ground and make sure you have secure connections
