Question about E-Machines eMachines Desktop PC
Lose video when the video drivers are installed
I just bought an EL1200-05w. Connected everything and went through the initial setup. Got to my desktop and a tools box opens and starts to download. It gets to 4 or 7 and the screen flashes and I lose video. The computer is still running, but I cannot see anything. If I reboot, it starts to load windows and then flashes off again. Any suggestions?
  • AngieB34 Mar 03, 2009
    How about the video driver does not work with my monitor? I tried two different monitors and got the same result. The data connector code pins are okay. new cable
  • 86 Answers
I think its monitor problem .so you can check the data conector code pin .those pin are ok or not .if pin not ok you can change your data conector code. then the problem no solve. so you can show hardware enginer and he solve them.
Posted on Mar 01, 2009
I'm having problems connecting. I ran the initial CD setup and everything seemed to run fine but when I try to access the 10.0.0.253 I receive an error message. The camera is set to wired and is...
"I receive an error message" (sic) What is it exactly, what happens? Also Install everything as Administrator, ALSO set the setup/install program's .exe in, Compatibility Mode for XP SP2. and Run the actual program's .exe as Administrator, too. Ensure all network settings are correct too.
Feb 22, 2010 | Panasonic BL-C131 Network Camera
AGP Card not Displaying Windows XP Pro
I have an Asus motherboard and need to install a sound driver for it please help
Dec 15, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
EVGA e-GeForce 6200
http://www.evga.com/support/drivers/default.asp?switch=2
Try downloading and installing this one
May 27, 2009 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Monitor stuck in standby..?
* Did the beeps go away when adding the new video card?
* Have you booted in "Safe Mode" (Press F8 before Windows starts).
In safe there are at least two options:
option - delete all the video adapter drivers then add the new one
option - change video adapter driver to Standard VGA
[If needed, write back for more instructions.]
* Also make & model of: computer (or motherboard) & monitor
Dec 03, 2008 | Computers & Internet
Unresponsive mouse XP unable to initialize device driver for Logitech LX8 laser mouse
Is your mouse new? if new maybe got factory defect. did you try your mouse to other pc? if not please try. if encounter same problem then, mouse is really defective. if not then, maybe your pc cannot support the mouse to run in the system.
melnavz
Oct 17, 2008 | Logitech Cordless Mouse
USB/Installation problem.
Normal 0 Did you install the software with the camera connected to the computer? Disconnect the camera from the USB port and reinstall the software. When the program asks you to connect the camera, do so, and it should work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chat on line after you install , either Skype or a messenger program.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Aug 08, 2008 | Computers & Internet
Sound only comes out of left channel, only dvd player works
I would Initialize Unit back to factory settings by turning off main power switch then hold both 6.1/7.1 surround and direct buttons ( they are next to each other near main power switch) in while turning un main power switch. Hold both buttons until you see all lights light up. Then check functions and setup like you bought it new.
Owners manual also explains how to initialize receiver
Feb 09, 2008 | Denon AVR-4800 Receiver
Drivers
I'm not sure if I understand clearly, you are having problems getting the driver cd to install?
Try a manual run by inserting the cd then go to Start>Run- then browse for the drive where the cd is located and then select open, you may need to choose install.exe of there isn't a setup.exe option
Jan 02, 2008 | Nvidia Geforce FX 5200 Graphic Card
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
