Question about Ubi Soft Splinter Cell 2: Pandora Tomorrow for PlayStation 2
Stuck in a compound unable to enter t.v station near end of game
  • 150 Answers
Try They have a walkthrough for this game
Posted on Mar 01, 2009
Hp 500 ploter adjustment karne pra 22:10 errer cord ata he
System error 21:10 is generated when the printer has detected a fault in the Service Station. Causes of this error can include the Service Station or Carriage. Follow the steps listed below to accurately troubleshoot the issue, and replace the appropriate parts.
Part Description Designjet 500 Models - C7769B, C7770B, C7769C, C7770C Designjet 800 Models - C7779B, C7780B, C7779C, C7780C Service Station Assembly (Required) C7769-60374 C7769-60374
    NOTE:If Removal and Installation instructions are needed for reference during any repairs performed, refer to the HP Designjet 500 and 800 Series Service Manual available on the Computer Care Web site for review or download. Troubleshooting steps If any of the troubleshooting steps listed below solve the problem, attempt to verify printer functionality (instructions listed below). If functionality is verified, no additional parts should be replaced.
      NOTE: The printer's current firmware revision must be A.02.04 or higher for a new Service Station to work properly. If firmware is lower than A.02.04, download the newest available firmware before continuing with the remainder of this document.
      1. Turn the printer off, then on to verify error. If no error attempt to verify functionality.
      2. If the error appears or problems persist, continue with the remaining steps.
      3. Follow the steps directly below to unlock the Carriage from the Service Station:
        1. Highlight the Set-Up menu and press the ENTER button.
        2. Press the UP arrow and ENTER buttons simultaneously and press the ENTER button.
        3. Highlight Service Utilities and press the ENTER button.
        4. Highlight Unlock Carriage and press the ENTER button.
        5. Unplug the power cord from the printer.
      4. Manually move the Carriage assembly out from the Service Station area and check for obstructions (remove as needed).
        NOTE: If you are unable to release the Carriage by the previous process, remove the right end-cover and locate the main Service station gear (as pictured below in Figure 1) and rotate it counter clockwise approximately four revolutions. The Carriage assembly should now be free from the Service station. Figure 1: Service Station Gear
        1. If an obstruction is found and removed, plug the power cord in, turn the printer On and attempt to verify functionality.
        2. If no obstruction was found or the problem persists, continue with the remaining steps.
        3. Disconnect the power cord from the printer.
        4. Remove the right end-cover from the printer.
        5. Open the top cover and manually move the Carriage to the left so that it is not over the Service Station (refer to Step 3 for instructions).
        6. The Service Station flag should be at about a 45-degree angle as pictured below in Figure 2.
        Figure 2: Service Station flag correctly positioned
        1. If the flag is correctly positioned continue with Step 16.
        2. If the flag is not at a 45-degree angle, press in gently on the bottom of the gray and rotate the bottom of the flag to the right (toward the back of the printer) until the top of the flag clips into the tab on the Service Station. The flag should stay at about a 45-degree angle.
        3. Plug in the power cord and turn the printer on.
        4. If no error appears, attempt to verify functionality.
        5. If the error reappears continue with the remaining steps.
        6. Turn the printer off and disconnect the power cord.
        7. Replace the Service Station assembly (refer to pg. 8-52 of the HP Designjet 500 and 800 Series Service Manual).
          NOTE: The printer firmware must be upgraded to A.02.04 or higher for the new Service Station to work. The new Service Station does not have an Aerosol fan and older firmware will check for the Aerosol fan, thus causing another system error.
          1. Following replacement, turn the printer on and verify functionality as instructed below.
          Verifying printer functionality
          1. Turn the printer on.
          2. Allow initialization to complete.
          3. Load media into the printer.
          4. From the main front-panel menu, select the Ink menu and press ENTER.
          5. Select Troubleshooting and press ENTER.
          6. Follow the instructions on the Front panel.
          7. Following a successful troubleshooting print, functionality is verifie
Sep 16, 2013 | HP Hewlett Packard Designjet 500 42" Wide...
Skil 3316 Compound Mitre Saw 10"
I suspect that the brushes have fallen out between the end bearing and the armature bars.. Try removing the brushes and see what happens.
May 18, 2013 | Skil 10-in 15-Amp Compound Miter Saw...
Some idiot so called mechanic has forced the wrong spark plugs into my car and cross threaded them...can i heli-coil all four? is this a good idea...and how can i get the cross threaded plugs out 3 are...
Likely, the plugs weren't cross threaded but I'll bet that anti-seize compound wasn't used. Plugs are not replaced as often as they once were and the dis-similar metals tend to corrode and bind so you end up tearing the threads out when you remove them. (doesn't matter now, result is the same). You can use heli-coils to do the repair...likely you can have them shipped if you buy them from an on-line source. Only problem is that you may not have enough room to actually do the install. As far as reliability, heli-coils will hold up indefinitely...Used them as routine on 7,000 hp fuel engines having very high cylinder pressures and never had one fail.
If you can get to them, you need to put a vacuum nozzle near the holes as you are drilling.(Removing them, they either will come out with the threads damaged or snap off....need to be drilled to accept the coil so that doesn't matter either) That should prevent most of the debris from entering the cylinders. Once drilled out and tapped, crank the engine over (ignition disabled) to blow any that did get in there out.
Other than removing / replacing the head, that's your only real option. And, of course, after making the repair, use anti seize compound so it dosen't happen again!!!
Good luck!!
Feb 28, 2011 | 1991 BMW 3 Series
GTA: Playback FM audio track causes game to freeze
if theres a ring on your disk im sorry but theres no fixing that just try not to play does radio stations i suggest you cut your radio off once you enter a vehicle if so try going to the options in the game and see if you can manually cut them stations or the radio off to avoid the freezing
Aug 05, 2009 | Sony PlayStation 2 (PS2) Console
How long will it take wendys $4000 investment,
Press APPS and select the Finance app. Select the TVM Solver.
Enter -4000 for PV, 0 for PMT, 6000 for FV. Be sure you use the (-) key for PV, not the - key. P/V and C/Y should both be 1 and PMT should be END.
If you want 5% annual interest compounded month, enter 5/12 for I%. If you simply want 5% annual interest, enter 5 for I%. Go to N and press ALPHA ENTER to see the number of periods (months or years according to what you entered earlier in this paragraph).
Feb 25, 2009 | Texas Instruments TI-83 Plus Calculator
Hello We purchased the Play station 2 game Heroes of Might and Magic (Quest for the Dragon Bone Staff). The back, of the game cd is blue. When we put it in the play station 2 we get the message disk...
If other games work fine on it, then the problem is with the game. If it is new, I would try to exchange it. If it is a used game, I have found that some of the used game stores can buff/resurface the disk for a small fee. The place I use charges $3.00 per disk. They can fix computer games and DVDs and all kinds of games.
Aug 22, 2008 | Video Game Consoles & Games
My son got the disk stuck and I think he mess the hard drive.
My 4 year old put two disk in at the same time, (play station 3) I'm unable to remove the disk. There are no screws to open the unit. How do I solve this problem?
May 27, 2008 | Video Game Consoles & Games
Playstation 2 games
check your disk for finger print and scratches
Feb 06, 2008 | Sony PlayStation 2 (PS2) Console
Ubi Soft Splinter Cell 2: Pandora Tomorrow for PlayStation 2 Logo
112 people viewed this question
Top Ubi Soft Video Game Consoles & Games Experts
Tom Chichester
Are you an Ubi Soft Video Game Console and Game Expert? Answer questions, earn points and help others
