Question about Panasonic PV-GS35 Mini DV Digital Camcorder
Panasonic PV-GS35 DV recording mode not function after replace..
Dear Sir,
My original problem, The PV-GS35 LCD screen flickers and goes blank when extended away from the camcorder. Then I follow someone's instruction to replace "LSXY0763" shaft case unit" from Panasonic parts (,350)
and the LCD issue has been solved.
BUT it bring me another problem, After I replace LSXY0763, the LCD working OK when it fully open., and all of sudden, I lost the "recording and "shooting photo" function. When I turn the knob to recording mode, the screen show "Blank" or I said "Black". The "Playback" mode is still good. I suspect something to do with the "len" ? Not sure ?
Please help me.
SOURCE: pV-GS35 to mac connection problems
Do you have another camera that you can use for testing? If so, try connecting that one and see if you get a picture on the Mac. If so, I'd guess a blown Firewire socket on the camera. If not, try a different firewire cable. If that doesn't fix it, suspect the firewire port on the Mac. If it's a Mac Pro, you might try adding a third-party FW card to the system. If some other type of Mac, you may need to send it in for repairs.
If you've completely ruled out hardware problems, did you upgrade QuickTime, recently? I've seen that that sometimes hoses the connectivity between Macs & cameras.
Posted on Feb 17, 2008
SOURCE: Can I have a driver for panasonic pv gs35 driver vista?
You don't need a driver. Just connect the camera using the cable provided with it; turn the camera on and set it to play movies. The first time it will upload the necessary drivers. THen, use Windows movie maker (it's included in vista, my version at least) to import the movie (if you don't find it, click on the start button and type "movie" on the search box). It's much better than the crappy software provided by panasonic anyways.
Posted on May 31, 2008
  • 10594 Answers
Please check Panasonic Support page for drivers update.
Posted on Sep 29, 2008
SOURCE: panasonic PV-GS35 camcorder
is you camcorder pal or ntsc?
Posted on Oct 20, 2008
SOURCE: LCD Screen goes blank after opening up
I actually have several of these cameras and have seen this happen many times with this model. The ribbon cable that goes from the body to the LCD tears in the same place in all of my experiences. If you look at the hing area, you can see the black coating on the ribbon cable between the body and the LCD. The top edge of this cable tears right where it enters the LCD component. If it works when only 1/2 way open, it's just a matter of time before it totally stops working...the damage has already begun. A replacement LCD runs >$100. Instead, I search e-bay for parts cameras. Just make sure that the description doesn't say that the LCD is bad.
Taking apart the camera isn't all that hard. Start with the e-bay parts camera just in case something goes wrong. Take off the lens cover (the lens actually stays attached to the camera for this entire fix) by removing a screw on the bottom, one just under the eye piece, one inside the LCD door area (near the top), and one inside the tape area...the one closest to the front of the lens. Then, the lens cover slides forward. Once you get it moving forward, extend the eye piece and the lens cover comes right out.
The 2nd step is to remove the LCD. The easiest fix is to remove the entire left side (LCD and SD flip cover). This is done by removing the 3 screws on the bottom (careful, 1 is smaller than the other 2), the screw in the battery area, a screw near the front of the lens, and 2 screws near the top (one above and 1 below the lens). Once the left side is free, tip it forward, exposing the 2 ribbon cables. The larger one is the LCD. Disconnect it by simply flipping the grey bar where the ribbon cable connects to the body up. The ribbon cable should come out with no effort. The other, smaller ribbon cable is the speaker and the "LCD is Open/Closed switch". Be careful with this one. Hold the white connector in place against the body (I apply pressure using a small, flat screwdriver). Pull the ribbon cable out of the holder at the body with your fingers (it should require only a moderate amount of force). If the white cable connector comes off with the cable, you're in trouble...the wires are extremely thin and difficult to get back in the right place...but it can be done.
Once you've removed the left side portion, do the same with the good LCD. Reconnect everything in the reverse order. I use a small needle nose pliers to put the small ribbon cable back into the connector. The larger one just slides in with little to no effort. Lock it in place by tipping the locking back back down. Once you've connected these 2 cables, you can carefully put a battery in and test that it works. If all goes well, remove the battery before continuing to put it back together again.
When you're done, put the parts camera back together again and keep it. You may need it for the lens assembly (I've had grease inside my lenses at times and the front lens can scratch easily, so a replacement is good to have around).
I've tried replacing just the ribbon cable, but getting it out of the LCD isn't worth the effort since finding a good cable usually means that you've also found a good LCD for the above proceedure.
You can find the repair manual complete with exploded views at
Posted on Mar 06, 2009
Can't tell if tape is recorded.
Well thanks that you found out. i was going to tell you to do exactly what you did because the timecode rreads where it is tapes and does not where it's not.
Nov 23, 2011 | Panasonic PV-GS35 Mini DV Digital...
The lcd screen has stoped working om my panasonic pv-gs35. the veiw finder still works. is there a mode i changed or any idea whats wrong...thanks, kyle
Dec 25, 2009 | Panasonic PV-GS35 Mini DV Digital...
Describe your Panasonic PV-GS35 Mini DV Digital Camcorder Problem: When I turn the camcorder on in the video camera mode the lcd panel and th evf show black, it does not show current picture to record. All...
There was an earlier post that explained the black ribbon between the LCD viewfinder and the body of the camera is split. You would have to buy a new LCD viewfinder for about $90 or send it back to them to fix for around $250. The same thing happened to my camera and I can actually is the split. If you close it down more than half way the picture shows up. I called Panasonic and they said you have to buy the whole LCD, that you can't just buy the ribbon. They don't even have a part number for just the ribbon. Good luck.
Oct 18, 2009 | Panasonic PV-GS35 Mini DV Digital...
Panasonic GS35
i suggest you insert a head cleaning casette to see if this removes the lines.the lines occur when one of the heads is dirty or not operating. if this does not solve the fault then the head might need changing.
Jun 16, 2008 | Panasonic PV-GS35 Mini DV Digital...
PV GS 35 wont play tapes from other cameras
perhaps it has to do with the SP and LP settings, I know certain video editing programs won't capture video recored in LP.
Aug 18, 2007 | Panasonic PV-GS35 Mini DV Digital...
No LCD Display when opened at 90 degree
Dear sir, If the Picture in View finder is connect, then problem in LCD ribbon cable. LCD Ribbon cable may damage. Replace LCD ribbon cable. thank you, replie if any problem
Jan 17, 2007 | Panasonic NV-GS35 Mini DV Digital...
Panasonic PV-GS35 Mini DV Digital Camcorder Logo
108 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
