Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Oil leaking from gear box on whirpool washer,theres no play inthe shaft,i just replaced the coupler,and 9 load later a puttle of oil was under the washer
  • 188 Answers
The seals on the gearcase (transmission) are defective. Check with your manual, the gearcase usually has a 10 year warranty.
If it's older than 1 year be prepared to pay for labor.
Posted on Mar 03, 2009
Spin cycle comes on but unit won't spin at all or very slow. also ther is some oil under gear box
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Two possibilities: since it will spin. None of the suggestions are very expensive.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the
transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or
spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If you pull the gearcase, you may see oil around the top cover.
You can remove the 8 bolts carefully (It holds 15 oz. of 80-90 weight gear oil) and re-seal the cover. I'd also check the plastic seal between the clutch and gearcase that keeps oil from leaking from the top of the gearcase.
Sep 30, 2010 | Kenmore 22422 Top Load Washer
Why does transmission not shift into park ?
Two reason are most possible
1. the possible play inthe shift levers that make the entire mechanism of the linkages move off center thereby reducing the motion. Can be failrue of the nylon washer or the position of the levers or the damage to the levers.
2. Problem within the gear box,fault inthe links or the notch adjusters,fault in the gear box link shaft.
Sep 24, 2010 | 2000 Oldsmobile Bravada
Oil leak from driveshaft n/s
not sure if you can interchange the manual & aut shafts, but you should check to see if there is excessive play where the shaft enters the gear box if so the diff bearings my be worn, if there is no play or noises from gear box when driving, remove the shaft again an try the seal on the shaft to check it's a proper fit, before fitting seals it is a good idea to leave them soaking in oil for a few hours prior to fitting
hope this helps
Regards
Jim
May 29, 2010 | Hyundai Motor S Cars & Trucks
Oil leak
If you have that old of a Kenmore washer than takes a belt, I would seriously think about getting a newer machine. If it is indeed the old style, check to be sure any wires didn't come off the wig-wam. Plus the brake has to be on the stud or it will not release the brake. The little bit of oil that has leaked out is not significant unless about a half a cup has leaked.But it involves removing the transmission. If it is the newer direct drive and you replaced the motor coupler, I suspect it could have broken one of the plastic drive cogs. They can split when you tap them onto the shaft. Put the new plastic parts on very hot water for a few minutes to expand them a little. They will go onto the shafts a lot easier. Or buy the coupler that uses the metal insert. They have less of a chance breaking during the install. Also, the same deal with the oil. If it's just a small amount, don't worry about it. The transmission needs removed and the top cover taken off to put gear oil in. If this helps, please rate my answer. Thank you.
Jan 07, 2010 | Kenmore 23822 Top Load Washer
Oil driping from motor assembly puddling under
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
It's quite possible that the cover plate on the transmission is leaking.
Pulling the transmission and taking the cover off is a bit of a messy jobv but not too difficult. It holds about 15 oz. of 80-90 weight gear oil.
See the following for how to pull the transmission.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=4abf73fe1a2397664d30a764bcbf56b4
You don't have to remove the tub to pull the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil
If the top of the case is leaking, you might try a gasket / sealer available at most auto repair / parts shops.
While you have the top off of the transmission, you might also want to check the condition of the plastic parts in the transmission itself.
Following is the Whirlpool / Kenmore PDf on how the transmission works and the parts inside it.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
w
Dec 21, 2009 | Kenmore 24032\24036 Top Load Washer
Whirpool Ultimate II Not spinning
Internal transmission trouble.
Jul 02, 2009 | Washing Machines
MyCrosley top loading washer,model CW7500 20 overflowed twice.
ok try this look under the washer between the motor and the transmission is a motor coupler it may have broken to get to it you need to remoe the motor and the pump very easy job but look between the motor and the trany and you will be able to see the coupler it should be two plastic coggs with a rubber coupler this is usually the problem
Jan 08, 2009 | Crosley CCW5294W Top Load Washer
GE Top Load Washer
There is a plastic coupler piece that goes bad under the agitator. The agitator pulls straight off with a little oooompf. The coupler is bolted to transmission shaft sometimes i have to use a puller to remove coupler as its seized to trans shaft PLEASE rate my help as solved as it darn good
Oct 02, 2007 | Kenmore 24872 Top Load Washer
Agitator not turning during cycle
Well, it sounds like you've done your homework. My first suspect would have been the agitator dogs too, but you said they were fine. Another likely suspect would have been the motor coupler, but you said the washer spins during the spin cycle. If the coupler was bad the unit would fill, but wouldn't agitate or spin. Plus, it would make an awful noise. I would have also suspected a clutch assembly, but you said the wash tub can spin. Normally, when the clutch goes bad, the drum won't spin, or spins slow. Another suspect could have been a bad lid switch, but the washer would have filled and stopped, without agitating or spinning. The only remaining suspect that I'm aware of is the gear case (transmission). Checking under the washer can give you some clues. Normally, when a gear case starts to go bad, they leak an amber colored oil. You may find puddles or drips under the washer. If you see no signs of oil the gear case could still be defective, however. But, before you go through all the trouble, double check the agitator one more time. Completely remove it from the tub and check the under side to ensure the grooves that grip the top of the gear case shaft have not been worn smooth. I hope this may have been some help to you.
Jul 09, 2007 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
236 people viewed this question
Dan Webster
Dan Webster
Sal De
