Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Need to replace tank bladder..
Where do i buy replacement
  • 27 Answers
Clean up at this website. >.o
Posted on Mar 01, 2009
How to install or replace bladder?
Hi Don! Installing a new bladder can be a little tricky. You'll need to pinch the opening on the bottom while pulling it through the hole on the bottom of the water tank.
If you need additional help, here's a link to contact us: http://www.bissell.com/contact-us/?cid=ccsocial
Oct 25, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Took inner bladder out now won't hold water
Inner bladder is needed to hold the fresh water for spray. Make sure the bladder is pulled through the bottom of the tank and that the black cap with a red rubber seal on the bottom of the tank.
If the black cap is missing you'll need to purchase a new one. Here's a quick link.
http://www.bissell.com/parts/?id=9143&sc=product&productid=2813&cid=ccsocial
Here's a quick link to locating a BISSELL Authorized Service Center if you need more assistance.
http://www.bissell.com/service-centers/?cid=ccsocial
Nov 13, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do i fill the water
There is a tank within a tank design on these deep cleaners. Use warm tap water and fill the inner bladder.
The Tank-in-Tank system is designed with a bladder inside for
clean water. As you clean, the bladder will empty. Dirty water
collects in the tank outside the bladder.
Apr 20, 2011 | Bissell 8910 ProHeat Clear View Upright...
My bissell pro heat turbo 9300 ...the bladder is not emptying so the carpets can be rinsed
There is a clog somewhere in your tank. Either in the bladder or somewhere in your tank. You can find replacement tanks here:
Proheat Parts
GoodVac.com
800-775-6586
Jan 13, 2011 | Bissell Vacuums
How do i replace the cap and water tank insert
The water bladder is hard to replace. The part that extends through the bottom has a "lip" on it that has to be outside of the plastic tank. I had a hard time getting it through. I rolled/folded the rest of bladder into a tube behind the hard plastic exit tube and forced it through.
Dec 12, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Where do I put the water.
1. Release the handle and lay the machine
handle back to access the tank.
2. Remove the tank from the base of the
machine by lifting the tank carry handle.
3. Carry like a bucket to the sink. Rotate the handle forward
to unlatch the lid. Lift off and set the lid aside.
4. Fill up the bladder with clean hot tap water.
*Do not boil or microwave water as it can
destroy the bladder.
5. Replace the top of the tank by matching the
lid and tank edges. Handle must be in the
forward position in order to replace lid. Rotate
Note: Remember to secure the lid and test to make
sure it is secure before picking up the Tank.
6. Place tank into machine base, seating firmly in place.
Rotate tank handle back into latched position. Bring
machine handle back into upright position.
You can download the manual from the Bissell website www.bissell.com
Jan 28, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell tank n tank assemble
Just insert the bladder into the tank, at the bottom, the lip of the bladder, pull it thru the hole then reinstall the autoload receiver(3 Screws).
Sep 14, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Older Bissell Proheat 12 amp black shampooer, BLADDER separate / LEAKS
Depending on the model yes:
Google turned up several sites -
http://www.svcvacuum.com/bissell/tanks.htm
You can also look at Bissell www.bissell.com
Jun 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have misplaced the directions for the Bissell powersteamer powerbrush. I need the directions for filling the u tank etc.
Release the handle and lay the machine handle
back to access the Tank.
2. Remove the Tank from the base of the machine by
lifting the Tank carry Handle.
3. Carry like a bucket to the sink. Rotate the Handle
forward to unlatch the lid. Lift off and set the lid aside.
4. Fill up the Bladder with clean hot tap water.
destroy the Bladder.
5.
Replace the top of the Tank by matching the lid
and tank edges. Handle must be in the forward
position in order to replace lid. Rotate the handle
to the carrying position to latch the lid.
make sure it is secure before picking up the Tank.
6.
1.
Lift the formula Tank up and out of the machine base.
2. To fill the Formula Tank, first unscrew the Cap
and Insert. Always use genuine BISSELL formulas
to maximize cleaning and for the safety of your
machine. Fill formula up to the line and replace the
Cap and Insert. Place Formula Tank back into the
base of machine, making sure it is seated securely.
Note: If bottle leaks, check for proper positioning
of red gromment and straw.
Apr 29, 2008 | Bissell 1699 ProHeat Clear View Upright...
Rubber valve at bottom of blader tank
It is called the (#69)auto load asm, part # 2107041. It would be wise to replace it, It will come as one piece. Is the bladder ok? You can call Bissell and maybe buy the part thru them or they can tell you where to go to get it(800) 237-7691 ) .
Feb 26, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
50 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
