Question about Raymarine C80 GPS Receiver
I have a Raymarine E80 interfaced with an AIS. The port setting for the AIS is required to be 38400. If I switch the AIS on - it makes the E80 reboot after about an hour - and the system loses its settings. Is there anything that can be done to fix this ? Thanks
  • 43 Answers
The software shoud be 5.23 for the E 80
If you have two E series maybe a E 80 and a E120 both MUST HAVE the same SOFTWARE
If not you can have problems like this.
Posted on Oct 22, 2009
    Scholar:
  • 76 Answers
First things first, be sure you have the most recent software version installed. You should have version 4.29 . Once that is established, if the problem persists you will need to call Raymarine's Tech support line and describe your troubles (since the problem is a bit unusual).
Posted on Sep 09, 2009
In Speedometer 6y5-83570-s6 there are two black wires which is ground and which goes to fuel tank?
My Raymarine E80 depth display kept freezing up (display then says "DSM connection lost"). Of course, this seems to happen more often when entering a tight shallow anchorage in Alaska's inside passage. Raymarine tech support recommended that I update the display software and then update the DSM300 sounder software. I did this to no avail. Then Raymarine told me to install a dashboard mounted toggle switch inline with the positive power input of the DSM300 module so I could do hard re-sets (turning off the system power or powering down the displays does not reset the sounder module). This I did. Now when entering a tight anchorage, the display still freezes, but at least I can do a hard re-set with the new toggle switch and have the unit back up in about 40 seconds (a life time in a tight channel with the current running, etc.). Now, Raymarine says that if I send in the DSM module to them, they will replace it with their new circuit boards that solve this chronic problem that they have known about for a long time (hello, this is a significant safety issue - why no recall?).
Don't mess with this - send your DSM300 in to Raymarine!
Bob S.
Aug 30, 2013 | Boating
I forgot password of my linksys switch srw224g4. can anyone help me in this regard
[1] Connect to the console port using terminal emulation parameters (typically 38400, 8, 0, 1, None) [2] Reboot switch (Remove power) [3] Hold down Ctrl U while rebooting --[a] Menu will be displayed [4] Select> [D] Delete file [5] Type startup-config (be sure that this is the ONLY file that you delete - if you delete other files, you[ will have to reload the firmware) [6] Now, you have erased the configuration file and you should be able to reboot and login with the default username and password.
Mar 14, 2011 | Linksys SRW224G4 24-Port Ethernet Switch
How to reset Networking Switch linksys sr2024
1. Connect to the console port using terminal emulation parameters (typically 38400, 8, 0, 1, None)
2. Reboot switch (Remove power)
3. Hold down Ctrl U while rebooting
a. Menu will be displayed
4. Select> [D] Delete file
5. Type startup-config (be sure that this is the ONLY file that you delete - if you delete other files, you will have to reload the firmware)
6. Now, you have erased the configuration file and you should be able to reboot and login with the default username and password
Feb 08, 2011 | Linksys SR2024 24x1000 Mbps Networking...
With the VHF on I can here the signal coming from the transponder, The orange indicator light soon changes to green pulsing gently. The E80 display unit displays ''No Data Source'' yet when the...
I would recommend upgrading the E80 and the DSM to the newest software levels:
E80 - 5.52
DSM - 4.12.
You can download the software off raymarine.com and load them onto different compact flash cards. Both softwares are upgraded through the E80 display.
Jan 29, 2010 | Raymarine St60 Plus Package, Includes...
How do i Reset or break in to get reset my password on 3Com 2948 Baseline Switch 48Port SFP Plus
The resetting of the password requires the installation of a console cable to the console port.
Be sure the terminal emulator program is set to VT-100 management using compatible, 38400 baud rate, no parity, 8 data bits and Console connection one stop bit.
Use the included cable, or be sure that the pin-out complies with a standard null-modem cable
Once the cable is connected, reboot the switch. Type a Ctrl/C until you enter the failsafe mode. This will be denoted with the prompt: “CFE>”
At the prompt execute the following commands:
CFE> passwrd
CFE> reset -sysreset
At this point the password has been reset.
Jan 20, 2010 | 3Com Baseline Switch 2948-SFP Plus 48-Port...
Connect Ratheon RL 70 to Raymarine E80
The two devices can share Nav data only. No radar, Sonar or Chart will be shared.
Hook the RL70 and the E80 together on SeaTalk and all data will be shared both ways. Alternatively, it could be done with NMEA 0183, which is directional, or you could also translate the RL70 data to NMEA 2000 and share it that way. As long as you have all Raymarine equipment, you are home free using a three wire Seatalk connection, with only two hooked up, Yellow and Bare, color to color.
Remember, this will share Nav Data only.
Nov 14, 2009 | Raymarine C80 GPS Receiver
I HAVE THE RL7OC PLUS. THE PORT TO PUT THE CHART
You can upgrade the port and the Software by a Raymarine Dealer
Jul 28, 2009 | Raymarine GPS
I just bought a raymarine c 70 with an evermore sa 320 gps, can anyone help with the wiring i have to do as i seem to have misplaced the instructions which came with the sa 320.
Hi
them works together nice !
connect SA320 green wire to RAY white and SA320 shield(black cover) to RAY green.SA320 red to 12 and black to ground(-).
Jul 21, 2009 | Raymarine GPS
E80 power button does not work, raytech says it needs to come to them for repair, can i fix myself? their repair is very expensive.
This is not a repair you can do yourself, sorry. Send it in and have it done right or you may regret it.
Jul 13, 2009 | Raymarine E Series E80 8.4" Display
Raymarine e-80 chart plotter keeps rebooting
If you are experiencing problems with your C70, C80, C120, E80 or E120 display resetting itself, or randomly turning itself off, there are 2 troubleshooting procedures that may resolve the issue:
1. Ensure that none of the buttons are stuck under the edge of the display's front fascia.
When the Multifunction Display is first installed, or any time after the front fascia has been removed, it is very easy to get the edge of one or more of the rubber buttons trapped under the edge of the plastic fascia. This is particularly prone to happening if the snaps that secure the fascia to the display are not fully engaged around both the outside perimeter of the fascia, and the insider edge surrounding the LCD display.
E-Series display with soft key trapped under fascia.
You can free the buttons from under the edge of the fascia by applying pressure to them with a fingertip, and rotating your fingertip in a circular motion. When the button is properly through the fascia it should sit centered within its hole, and you should feel a positive "click" of the internal switch when pressing and depressing each button. If trapped buttons were found, releasing them will return the display to normal operation.
2. Reset the display.
Your display may require a reset which will erase any stored waypoints, routes and tracks.
If your MFD's menus are accessible:
Backup your personal data CompactFlash memory card. Please see Answer #1145, Backing up waypoint, routes and tracks on C and E-Series for complete instructions.
Once your data is backed up you can reset the display using this procedure:
  1. If your MFD's menus are accessible, perform a "Settings and Data" reset from the System Setup menu. Press the MENU key, then scroll down to the "System Setup" option, and toggle the track pad right.
  2. Scroll down to the "Settings and Data Reset" option and toggle the track pad right.
  3. Under the word "Factory Reset?" press the softkey corresponding to YES. The display will restart momentarily.
  4. The display should reboot into normal operating mode.
If your MFD's menus are not accessible:
You will not be able to backup your personal data. We can reset the display though using this procedure:
  1. Press and hold down the first soft key (next to the power button.)
  2. Keep holding the soft key down while the display reboots. A "Factory Reset" countdown will be displayed. Keep holding the first soft key until the countdown is complete.
  3. The display should reboot into normal operating mode.
Once your display has returned to normal operation you should check its operating software version, and upgrade to the latest version (if applicable.) The latest update for your model is 3.31. It will be displayed on the message that appears during start up. This is an important update because changes were made to the WAAS satellites and your E80 will not recognise the satellites without this update. Click this link to download the update: Raymarine V3.31 update.
You may need to create a free account if you don't already have one.
Mar 09, 2008 | Raymarine C80 GPS Receiver
Raymarine C80 GPS Receiver Logo
342 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
