Question about Refrigerators
Whirlpool REfrigerator Freez WRN38RWG6 How do you stop water
Whirlpool WRN38RWG6 How do you stop water leaking over the floor
  • dannyred13 Mar 30, 2009
    i put the lever up and the water is still leaking over flowing and not making ice. flooding my kitchen
Turn Fridge off,leave open for 24 hrs,then shut doors and start.The defrosted water had frozen up high and the fridge then leaks
Posted on Feb 20, 2010
Whirlpool God 26cu ft French Door Refrigerator Model # GI6FDRXXY02 is leaking water on the kitchen floor. The water appears to be leaking in the front & water is leaking on both sides. Has anyone ha
There is usually a condensation pan at the bottom of a fridge. This can fill with water and over flow, causing what is happening. Also, the ice maker could be causing the problem because the water connections can leak at the back where they connect to the house water system.
Feb 03, 2015 | Whirlpool Refrigerators
Whirlpool refrigerator with top freezer
If there is an ice maker in the freezer, look to see if the water is coming from there. If it is then replace the solenoid valve where the water comes into the back of the refrigerator.
Mar 05, 2014 | Whirlpool Freezers
Water leaks out on the floor from Kenmore refrigerator mdl 253.7482240h
Be sure the drain line is clear from the bottom of the freezer to the drain pan.
Feb 01, 2014 | Whirlpool ET1MHKXM Top Freezer...
Whirlpool Wrn38rwg6 Freezer isn't freezing and I
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Sep 16, 2011 | Whirlpool Refrigerators
Water is leaking in the bottom of the freezer, also coils are freezing up with ice, this problem is causing water to leak onto the floor from the freezer
when the cold coil is freezing up this is caused by a failed defrost system ( a bad heater or terminator . or the aditive defrost control . it also will freez the drain in the back of the freezer and this will cause the water to end up on the floor . . i would defrost the frig and repl the terminator . the heate is usualy good . and if problem comes back then replace the a d c . // the a d c pt # 241508001 and the terminator 5303918214 . this is a very common problem .. mm hope this helped and thanks for using fix ya ..
Oct 31, 2010 | Frigidaire FRS3R5EMB Side by Side...
I have a Whrilpool refrigerator, model #
the drain hose to the base is plugged that sends water to the lower area by the floor to evaporate
Aug 01, 2010 | Whirlpool Refrigerators
The water dispenser will sometimes drip and doesn't stop. It doesn't stop by pulling forward on the lever, I have to push it in as though I'm dispensing more water and that usually stops it. If I don't...
There may be several reasons for this like a leaking water control valve, air in water lines or you may just need to replace the dispenser water line with a kit Part Number 8201537 Try unplugging the dispenser power on rear of refrigerator and tell me if that stops the flow. let me know, Sea Breeze
Apr 20, 2010 | Whirlpool 25.2 cu. ft. Side-by-Side...
Whirlpool Wrn38rwg6 frige has decided to not cool properly
My first thought is it defrosting? Look into rear of the freezer and see if ice is building up on rear wall of freezer. If yes manually defrost and let me know what you find. If no I would want you to feel compressor for overheating or look and see if a fan has stopped working while compressor is running. Sea Breeze
Feb 20, 2010 | Refrigerators
The water and icecube dispenser constantly leaks water on floor
Needs new solinoid valve. Usually located on the back bottom of refrigerator
Jan 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
688 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
