Question about Intel Celeron D 325 2.53GHz 533MHz 256KB Socket 478 CPU (Bulk)
HELP with with Intel celeron d 325
Can i use 2gb DDR2 ram on celeron d 325 CPU ?
What is the maximum amount of graphic memory supported by Celeron d 325 ? or Maximum MB of graphic card supported .
My mother board is Intel® Desktop Board D845GVFN
AND what is slot supported for graphic card in celeron d 325
AGP,PCI,PCI Express or something else
PLEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEZE help me
  • 27 Answers
Phew, k3! A ton of questions and even more confusion going on here!
Firstly (love that non-word), your Motherboard accepts DDR Ram. Unfortunately, DDR2 will not be compatible. Won't work. Sorry. It does accept up to 2gb of DDR Ram, though.
Second, for Graphic Card slots, it has 3 x PCI slots (NOT PCI-Express), which are great for G-Cards. Maximum amount of memory won;t be affected by your MB, but by your processor and ram. As long as it has a PCI slot for a PCI card, you'll be good. Just be sure to turn off integrated graphics in BIOS settings.
Thirdly, good luck. Opening up the side of your PC can be daunting at first. Ensure you either have the patience to learn before you touch or have the money to continue learning as you go. >.o
Posted on Mar 01, 2009
Dc5100 processor upgrade
NO!
Two Netburst based Processor cores on the SAME chipset?
Get outta' here!
When did they come up with that?
OH, I'M JUS KIDDIN'!
http://h18000.www1.hp.com/products/quickspecs/12145_na/12145_na.HTML
The HP Compaq dc5100 Desktop PC uses an Intel 915GV motherboard chipset.
Since we know that the Northbridge chip, of the motherboard chipset; handles the Faster capabilities of a computer;
i.e., Processor, Ram Memory, and HIGH-speed graphics; let's look at the Intel 915GV chipset,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4.2FPentium_D.2FPentium_EE_chipsets
No sir/ma'am.
The Intel 915GV motherboard chipset only handles Single Core processors;
Intel Pentium 4,
and,
Intel Celeron,
and,
Intel Celeron D.
(With a 533MegaHertz Front Side Bus, or an 800MHz FSB)
The Celeron D is NOT a dual core processor,
http://en.wikipedia.org/wiki/Celeron#Prescott-256
"The D suffix actually has no official designation, and does not indicate that these models are dual-core. It is used simply to distinguish this line of Celeron from the previous, lower performing Northwood and Willamette series, and also from the mobile series, the Celeron M (which also uses 3xx model numbers) Unlike the Pentium D, the Celeron D is Not a dual core processor."
Yeah, I know. I'm just a 'Ray of Sunshine'.
You know you can pick up a motherboard pretty cheap nowadays, that WILL support the lowly Pentium D, for not much money.
Problem is you will need to replace Ram Memory also.
By the time you get a motherboard chipset that supports dual core Processors (CPU), you are going to be using DDR2 Sdram ram memory, instead of the DDR Sdram ram memory you are using now.
OK, Motherboard, CPU, and Ram Memory.
Oh, the Power Supply. Won't do either.
240 Watt unit, or 300 Watt unit?
Sure.............OK.
Back in the day those Power Supply's were made, Power Supply manufacturer's were 'fudging' the actual maximum rated Wattage.
True Wattage was more like 60 to 70 percent of what was stated.
Why?
SOLD more Power Supply's.
240 Watts?
Simply divide by 10. = 24.
For 60 percent, take 60 times 24. = 144 Watts
70 percent? 168 Watts.
300 Watts?
60 percent is 180 Watts.
70 percent is 210 Watts.
I wouldn't try to run a Barbie doll with that low a Wattage, of Power Supply. (Barbie doll? What?)
Need at least a decent 350 Watt power supply, from today's manufacturers.
80 percent constant duty cycle, for most good units; or higher.
So...............
Max out the Intel Pentium 4 CPU.
4GB's of 533MHz DDR Sdram ram memory.
(PC4200, or PC4300. Depends on the manufacturer as to how they name it)
By the time you spend that much money, you may as well buy another Motherboard, Processor, Ram Memory, and Power Supply.
Yes, may as well buy a better computer.
I know. Quit trying to cheer you up.
Around here we have Craigslist, and Ebay, for two places.
Could pick up a better computer, for around the same money, as you would pay for all the upgrade parts above.
Which is better? Upgrade the Processor, or upgrade the Ram Memory/
For the better 'Bang for the Buck', upgrade the Ram Memory.
The CPU (Processor) has a built-in cache.
L1 cache, and L2 cache. (Newer CPU's have an L3 cache)
The Cache is a small memory area for the CPU.
It is the FIRST memory area the Processor (CPU) reads.
This is because it operates at the same frequency rate, as the CPU does.
(Frequency rate = 'Speed'. Operates at the same 'Speed')
Next inline is the Ram Memory.
Ram Memory -> typically, operates at half of the Processor's Front Side Bus. (FSB)
This is why upgrading Ram Memory is a good idea.
It isn't so much of getting Ram Memory, that operates at a higher frequency rate ('Speed'), as it is to have MORE ram memory.
Example;
PC3200 compared to PC4200.
4GB's of PC3200 is better than 2GB's of PC4200.
(DDR Sdram at 400MHz = PC3200)
Moving on............
Motherboard chipset:
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The motherboard chipset for your computer, consists of a Northbridge chip, and a Southbridge chip.
{Motherboards that support the Intel Core i technology, (Core i3, Core i5, Core i7, etc), do NOT use this motherboard chipset technology. Neither do some of the AMD CPU's }
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
As stated previously, the Northbridge chip handles the Faster capabilities of a computer;
Processor (CPU), Ram Memory, and HIGH-speed graphics.
The AGP technology, and the PCI Express technology; ARE high-speed graphics.
Using a graphics card in a PCI slot, or using Integrated Graphics; is NOT high-speed graphics.
The slower capabilities of a computer are handled by the Southbridge chip.
1) PCI Bus / Integrated Graphics.
(Another term for Integrated Graphics, is OnBoard Graphics. A term that seems to have gotten lost.
It explains better; ON the motherBOARD )
2) IDE Bus
3) SATA Bus
4) USB Bus
5) Ethernet
6) Audio (Sound)
Point?
Look to see what the Northbridge chip is, as I have shown you; and you'll get a good idea of what Processor (CPU) support is.
For additional questions please post in a Comment.
Regards,
joecoolvette
(I get tired of looking on websites, that just say NO, and do not explain why )
Mar 06, 2013 | HP Compaq dc5100 PC Desktop
I need to know how much main memory that supports my motherboard.
According to Intel:
(DIMM) sockets
• 800/667 MHz single or dual channel DDR2 SDRAM interface
• Support for up to 8 GB of system memory
Nov 10, 2012 | Intel Gateway E210882 Motherboard With...
What is the hidhest ram i can use on a celeron 2.6
Hi. The amount of memory that can be installed is limited by the motherboard, not the CPU. That being said, the motherboard you have listed will take the following memory:
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.
Sep 28, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
How to increase video memory
If your video card uses a portion of your system RAM you can adjust the amount it uses through the BIOS or the advanced settings of the Driver Software.
Typically, the amount of video memory is locked because it's integrated to the video card; the only way to upgrade the card capabilities is by upgrading the card itself.
If you have an Integrated Intel Graphics Accelerator follow these links:
http://support.intel.com/support/graphics/detect.htm?iid=business+download_gmav
http://www.intel.com/support/graphics/sb/CS-029090.htm
http://www.intel.com/support/graphics/sb/CS-003999.htm
Mar 11, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Need to buy a new Mother Board?need some help
Now a days every motherboard is come with PCI-Express Slot and this mothrboard can also handle more than 3.0Ghz CPU and it support DDR2 RAM which is faster than DDR1 RAM.
High FSB and high storage of DDR2 RAM will increase your computer performace.
DDR2 RAM FSB is depend on your motherboard choice. Because your motherboard should be able to support your RAM FSB rate.
Mar 05, 2009 | Intel Motherboard
Can i use 768MB of graphic card in Celeron d 325
¨Hi!
You can use 768MB GPU if your mobo alows it. It dosent have anything at al to do with the PSU.
Good luck
Nic
Mar 04, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
Maximum MB or GB of graphic memory supported by Celeron d 325?
you can as high graphics card as you want as long as the is a PCI card.
hope this helps.
please rate good.
Mar 01, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
Intel Celeron D 325 2.53GHz 533MHz 256KB Socket 478 CPU (Bulk) Logo
137 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
