Question about Fisher Paykel EcoSmart GWL15
Black marks on clothes
I have a fisher and Pakel Smart Drive (top loader) and when the load is finished I notice blackish / greasey streaks on the clothes.
  • 2 more comments
  • wantsomehelp Mar 01, 2009
    My Fisher and Paykel top loader is doing the same thing (leaving black marks or streaks on my clothes!!!  What is causing this and how do we stop it?
  • yvonne1966 Mar 09, 2009
    I also have the same problem with balck/grey marks on the clothing
  • pappy4 Mar 13, 2009
    I also have the same problem from time to time. Not sure what is causing this. The only place I can think of would be clothes getting caught between the base of agitator and base of drum.
  • sfkitchdds Apr 07, 2009
    Love the machine, but it ruined a great silk sweater on about the 5th load I ever did. Wasn't sure what the black marks were, so I didn't know what was best to remove them. Now they are probably set for good. Still love the machine, though.
I had a similar problem. We has placed the waste water hose into an old tub next the machine. The plug hole int he sink has become blocked with lint. When the washing maching was pumping water into the tub, the tub would fill with water, which would rise a level higher than the washing machine waste hose. What this appeared to do was cause the machine not to be able to properly pump out water, leaving this horrible back stuff in the wash which would end up all over the wash. Ensuring the plub hole in the tub was clear solved the problem immediately!
Posted on Jun 02, 2009
Fisher and Pakel WL26CW1 code 246
i would say its one of the boards usually the main motorcontroller
Jan 11, 2013 | Fisher Paykel Fisher & Paykel AquaSmart...
Fisher paykel aquasmart top loader washing machine continuously comes up with fault 247 when trying to spin. Appears to be a balance problem as rearranging clothes and a restart allows it to...
Hi - you have possibly some restrictions in/around your smart pump unit, inside is a flapper valve suppose to control flow in both directions, often this gets the rough treatments.
Be careful if you wish to have a nosy its located beneath the smart agitator.
Jun 18, 2011 | Fisher and Paykel Washing Machines
Machine gets stuck between rinse ans spin and sits for a while then spins but wont stop, then **** from the in the machine or hose is on the clothes???? Any suggestions? Machine is a top loader smart drive...
You could try a hot load with epsom salts....this will clean out the machine....Make sure it is with hot water. It goes slow in between rinse and spin possibly because it is slow draining...clean out the pump. Also as it FILLS make sure the water runs in properly and not just trickle in making a hissing noise. Good luck. Tony the technician.
Apr 02, 2011 | Fisher and Paykel Washing Machines
Lg washer leaving black greasy marks on clothes
This is usually to do with fabric softener. Dilute it with more water. The fabric softener makes clots, and these make the marks on your clothing.
Hope it helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM2077CW XL Front Load Stackable Washer...
Fisher Paykel washer GWL15
I have noticed this same problem and wonder if it because my FP washer wasn't draining properly and dirty water couldn't get out. See my post on "eco smart won't drain, smells hot". I found one of my husband's socks when I removed the black motor/white plastic housing on bottom of washer. tip washer back and you'll see this electric motor. My post tells how to remove it. then you can look into that small space and see if there is something plugging it.
I am waiting on my replacemt motor, and hoping all the dirty streaks are gone. the water I drained out after i removed the sock was really grimy and gritty with dirt. I'm sure the sock has been holding a lot of junk in the bottom of the tub and it would end up on clothes during spin cycle. My issue has been going on for a few weeks and then the motor finally smoked which led to the sock discovery!
Oct 02, 2008 | Fisher Paykel EcoSmart GWL15
Black oil or grease on clothes after washing
is you machine a top loader or front loader? if its a front loader the black marks could be from the boot. WIpe the boot with a good cleaner. and try not to over load machine. and if it a top loader your transmission is probably leaking oil back into clothes tub. You could have it rebuilt $$$ or better replace the machine.
May 22, 2008 | Washing Machines
Front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Sep 18, 2007 | Kenmore 46462 Front Load Washer
Fisher Paykel EcoSmart GWL15 Logo
453 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
