Question about Philips Magnavox DVD/VCR Dual Player
I have a/v connections on my tv. In order to
I have a/v connections on my tv. In order to watch a video, I have to switch my tv to either Video 1 or video 2. How can I record on a vhs tape from cable?
    Problem Solver:
  • 8 Answers
Hook up your tv output to your vcr in put or if you have a cable jack you can hook your cable to your vcr input and the out to your tv you will either have to change the channel to3 or4 or change the tv video input
Posted on Mar 01, 2009
I have a sharp lc30hv6u LCD flat screen TV I'm trying to only watch TV what cable do I need and what is the difference between inputs 1 2 & 3 thank you
You need to re-thnk how this tv works. The AVS system box that came with the TV which is at the bottom of your picture controls the inputs. So a TV antenna goes into the ANT-A in the top left corner of the back of the AVS system box. The AVS cable has to connect the TV to the AVS system. So the inputs 1 2 3 have to be all connected . I assume to watch TV you need to somehow tell the AVS system to switch the AVS to TV.
I have seen a similar system with an after market sound and video processor that switches the audio and video to the tv from many different sources.
Mar 13, 2017 | Sharp Televison & Video
Should my Sanyo tv be on HDMI......or Video 1......Video 2 ???
Depends on what is connected to the HDMI ports on the back of the TV. Same goes for the video 1 and 2 ports. Example: If you have a blu ray player connected with a HDMI cable, then you would use whichever HDMI number you connected the cable to on the TV in order to watch the player. Same goes for video. If you have a satellite receiver or VHS tape recorder connected to video 1 or 2, toy would select them to watch that source.
Dec 06, 2016 | Sanyo Televison & Video
Trying to connect HP M9060N and Sharp Aquos through Denon AVR 1508, only get 'no signal' response. Have HDMI 1 set to DVD, HDMI 2 to AUX, HDMI 3 to TV, which is order of HDMI outlets on receiver.
Depending on your TV inputs, you are better off to run video componenets through TV first then, connect TV to reciever via digital optical. Recievers have video pass through but, noyt the best route. You can use TV's menu to choose what you watch and, only have the one output from TV to reciever. Make sure you scan through TV and reciever menus to make sure you are selecting the right channel.
Jun 21, 2011 | Denon AVR-4306 Receiver
Have connected cable (white, yellow, red) from Conia DVD player to TV as component 1 and connected Sony VHS cable (white, yellow, red) to TV as component 2. What other steps need to be taken for the...
component video needs Red, Green, Blue to be connected on the DVD end and to the TV for video to display, also the Red and White audio out needs to be connected to the TV for audio to work .
VHS has Red, White an yellow for Right Audio, Left Audio and video respectively.
You need to switch the inputs on the TV to the corresponding Component and Video inputs. Most TV's have a source or Input button to switch between the inputs. simply press the button until you have the input you are looking for.
Mar 13, 2011 | Televison & Video
Mitsubishi CS-35301 35 in. rear projection. can't switch inputs
if you have s video connected some tvs wont allow you to use input 1 or 2.disconnect s video cable and try that other wise you got something wrong.
Apr 25, 2010 | Mitsubishi CS-35305 TV
CONNECTING DTV CONVERTER AND STILL USING DVD PLAYER
Get a set of video cables to connect the DVD player to the TV.
Then follow the numbered instructions in this post to connect the DVD player, and use your TV remote to switch the video mode when you want to watch a DVD, then switch it back when you want to view TV.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jan 24, 2009 | Toshiba 32AF42 32" TV
Dvr4-alert full screen playback
That's because this is a quad. It compresses all 4 video feeds into 1 file. When you play it back, it decompresses the video and shows you each camera. Playback through this unit is the only way to see 1 camera at a time.
To be able to copy 1 camera shot to a DVD, this is what you need to do: You need to have a TV with Video in and Video out jacks.  Connect the Quad to the TV Video in jack and connect the TV Video out jack to your DVD Video in jack. Playback a single camera shot on the quad to the TV and hit record on your DVD. - The DVD will record whatever is shown on the TV.
Oct 26, 2008 | Home Security
HDMI connection???
Hi Greg,
Again, if you have a high definition dish box with HDMI output,and a dvd player with HDMI output,please connect them both directly to your TV HDMI inputs.
When watching TV(dishnetwork box).remember to switch the HDMI video inputs.
Same as your DVD player,you need to switch it under your TV video input.
solutiondoct
May 28, 2008 | Denon AVR-2807 Receiver
How to connect surround sound system, at the moment its connected through cable, each time we use the dvd player we have take them out of the cable box then into the dvd player, we have a LG 42PC55 tv.
In order of picture and sound quality -- from best to worst:
1. The best way to connect, assuming your TV and A/V Receiver and/or Cable Box have the jacks, is to use a HDMI cable ( this cable is for both sound and video).
2. Use Component Video out to input (3 RCA plugs, Red, Blue & Green) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
3. Use S-Video out to input (1 din plug) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
4. Use Video out to input (1 RCA plug, yellow) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
Be sure to select the correct inputs on your TV and Audio/Video receiver when you are watching TV. For example if you have connected your TV to HDMI 1 and DVD to HDMI 2, you will not see or hear anything if you don't select the correct input on your TV and A/V receiver for the input you want to see and hear.
Detailed connection instructions will be found in your owners' manuals.
Hope this helped you. :)
Mar 30, 2008 | Televison & Video
Sanyo TV
If I understand your posting/description right, you have:
1, a Sanyo TV with only 1 video input;
2. you have a DVD player with only video output; and
3. you have a VCR (which I will assume to be with both video input and output).
Your query, if I may clarify, is how to hook them up so that you need not connect/disconnect any video cable when you want to switch video source from either DVD or VCR.
If that is what you want, then connect:
a. audio/video OUT of your DVD to audio/video IN of the VCR;
b. audio/video OUT of your VCR to audio/video IN of the TV.
The above described connection would allow you to:
i. watch DVD movies on your TV (your VCR must be powered ON and set to Video INput, your TV must be powered ON & set to Video INput);
ii. watch tape movies from your VCR without disconnecting/connecting cables.
Additionally, this arrangement would allow you to record DVD movies in your VCR. Further, connecting your cable/aerial to the RF INput of your VCR would allow you to do the same with a TV/Cable program.
Incidentally, if one of your units (TV, VCR, DVD) would only have a single audio input, it is still possible since some models uses the white audio RCA connector as either left or mono, the red is right. You can also use a 2 female RCA to 1 RCA male adapter as shown below to joint the red/white audio.
Hope this be of some idea/help. Pls post back how things turned out or should you require additional information.
Good luck and kind regards.
Nov 19, 2007 | Sanyo DS32224 TV
Philips Magnavox DVD/VCR Dual Player Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
