Question about Samsung SCX 4521F All-In-One Laser Printer
Fax not going out/coming in
I get dialtone on hook dial.However ,it gives error in fax out going
i am using samsung scx-4521f and phone line is VOIP.
    Sergeant:
  • 199 Answers
Connect a phone with 4521 in the back side jack of phoneout,
for outgoing fax
place original in the adf or glass for fax
Press hookdial and dial your sending fax number in 4521 after number dialing pull the phone handset to ear when you leason fax tone from the dialing number press start button to send fax.
for incoming fax (in not automoated)
press hook dial and press start to receive
Posted on Mar 01, 2009
How to send fax from samsung scx-4521f
Dear
Connect the telecom line to the socket marked LINE at the back side cover. Put the document on the platen glass or ADF face upward. Press OHD to get dial tone dial the required fax no. hear the call progress tone of fax press START key. Some model display 1sending 2receiving. Press 1 to send.
Thanks.
Aug 04, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Why no dialing tone on fax machine?
Unplug the phone calde from the fax machine and plug it in to phone. Do dial tone, is the other end connected to the outlet in the wall? Do you have a phone line to use as a fax line?
May 19, 2014 | United Stationers Samsung Scx4521fg...
What can i do if my samsung scx-3405f printer dosent want to fax
make sure you dial the area code to.also make sure you telephone line woks.plug the line into a regular phone in to make sure you have dial tone
May 19, 2014 | Samsung SCX 4521F All-In-One Laser Printer
How ican send a fax with samsung scx-4521f?
hello
first you connect the telephone port to your machine and telephoe line.
.then load your fax document to ADF. then their is a button in your machine its name ON HOOK DIAL .press it then you can here some dial tone. press fax number if you wont to send. then you can here some ringing tone and press start button after fax tone coming.
Jan 12, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I got samsung scx-4521f when receving fax, I am only receving first top quater of the page and the display reads comm.error
possibly a the line is too noisy. connect a phone to it dial 1 and listen for any sounds.
Good line should be quite.
Nov 10, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Faxes are being dropped
Do you or the sending party have a DSL or some other kind of DIGITAL phone line?
Jun 19, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Cannot receive faxes on Samsung SCX-4521F
I'm not sure if I can help you or not, but I do have a suggestion or 2, that may help isolate the problem.
The solution I gave you initially, is the usual culprit for the situation you are experiencing. If the machine can "send", then "receiving" is not normally a problem, as long as the reception settings are correct. You said that "sending works fine"?
Since you have multiple faxes, you might try swapping the locations, or at least try the Samsung in a known working environment, to see if it behaves the same. If it works on another line, then try the other fax on the "Samsung" line.
That's all I have to suggest right now, but I'd be anxious to hear if there is any change.
Apr 25, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Setup FAX...
Plug a phone cord into the LINE port of your machine. Ideally it should be a dedicated phone number, but you can share a line.
Sending a fax is just like making a phone call.
Load your original face down , dial the fax number, press send or start.
Receiving will be automatic.
Mar 15, 2009 | Samsung SCX 4521F All-In-One Laser Printer
No faxes outgoing
Turn the machine round and make sure that you haven't fitted the telephone cable into the phone slot. if you have remove the cable from the machine and plug into the other slot that is usually indicated by a letter L. Once done this try the on hook dial and hopefully there will be a dial tone. If there is not then try a different telephone cable if still the same problem then unfortunately the modem card is faulty and will need replacing.
Thanks J
Jan 10, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
511 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
