FixYa.com
Tags:
Quantum Meridian CD Net Internal 24x CD-ROM Drive
Al440lx problem with harddisk and cd-rom drive
By LiZzIe - usenet poster
my configuration is al440lx(bios 4a4ll0x0.86a.0027) with pii 300 quantum 3.2gb hd and 24x ide cd-rom drive, without the cd-rom drive the harddisk boots up fine, until i plugged in the cdrom drive the motherboard seems to detect the cd-rom drive as atapi blah blah then doesn't detect my harddisk at all. then it would go missing operating system. harddisk is on pri master and cdrom drive is on pri slave. please reply asap.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 14, 2007
Not Rated (0)
del2007
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
what defferents of harddisk primary and CD Rom secondary slave
Comment by del2007, posted on Dec 14, 2007
what the basic of dot matrix
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 02, 2007
Not Rated (0)
Beresford
Beresford - usenet poster
Rating: 0%, 0 votes
Hi Mervyn,
The optimal configuration is to have the hard drive(s) on the Primary IDE
channel and the CD-ROM on the Secondary IDE channel. Also make certain to
set the "strapping" (aka Master / Slave) properly and appropriately. Some
hard drives have "3" settings, Single, Master, Slave, I have yet to see any
true ATAPI CD-ROM have anything other than Master / Slave. You may need to
purchase an additional IDE ribbon cable but the couple of dollars is worth
the increase in system performance and fewer headaches.
Once you've recabled your drives separately make sure you go into the BIOS /
CMOS and set the "Reset Configuration Data" to YES and, if you're running
Windows 9x, make sure that Plug and Play OS is also set to YES. If you
experience "slow windows startups" you may also experiment with setting the
CD-ROM in the BIOS to NONE instead of either AUTO or CD-ROM.
Hope that helps, write back if you need more info.
Vic ... ;-)
Solution #3
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rating: 0%, 0 votes
Try moving the cdrom to the secondary ide connector. You might also set the
so it doesn't auto-detect the cdrom.
Good Luck
Bob Martin
Can you Help with these CD ROM Drives problems?
CD ROM Drives
cd rom for a206x
need cd rom for this model... Answer This...
CD ROM Drives
LG GDK 70
I am looking for LG GDK 70... Answer This...
Quantum Meridian CD Net Internal 24x CD-ROM...
please enlighten me on this
Which of thsi is... Answer This...
CD ROM Drives
cdrom often lostii
i am having compaq presario... Answer This...
harddisk primary slave and cd...
defferents and with diagram Answer This...
Repair Service
Find CD ROM Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
