You do not need to remove the motor but you do need to take the front of the dryer off the door and front panel come off one of 2 ways. Ckeck at the very bottom of the dryer front panel if you have 2 screws there take them out and lift from the bottom carefully. Disconnect the two wires that connect to the door switch and un hinge the top from there you should be able to see wht else you'll have to take apart. If you don't have those two screws, then you have to pry the top up with a wide flat screw driver about an inch and a half in from edges from there look inside the front panel toward top and take out 2 screws and pull top of front out disconnect door wires and lift out. Good Luck
