Question about Acer Computers & Internet
I'm trying to add software to my Acer desktop but the door won't stay shut after I put my disk in??? The first time I tried, it sounded like a train was going through the computer, after that the door won't stay shut.
  • fmr888 May 11, 2010
    you need to replace the CD drive. they are not that expentive and you can get an external usb that when you use it, it works great. i had to do that to complety reintall my older machine with XP on it. but it turned out that it was over heating and the on off switch was also bad.
    President:
  • 1,223 Answers
Actually the inner mech which is made of plastic parts normally gets faulty or broken , there is no solution to that infact replace the drive with a dvd writer very cheap nowdays
pls rate me
Posted on Mar 02, 2009
Laptop error, please help!
sounds like you may have a bad harddrive try to do a check disk on it or if you have a spare hard drive put it in and see what happens
Jan 18, 2013 | Acer Aspire ONE 725-0688 laptop
I was restoring from the Acer recovery disk that I created when my process crashed before it completed. Now it won't boot up at all...HELP!
Your best bet is to reinstall the operating system. I couldn't count the number of times that the Recovery Discs created by users fail, it's very common. The only recovery that works a high percentage of the time is when the manufacturer puts a recovery partition on your hard drive.
You can try your Recovery Disc again, but if it produces the same results, just reinstall your operating system fresh. It shouldn't matter because either way you will lose your data.
May 13, 2012 | Acer Aspire T160-US321H (AST160-U-S321H)...
I cannot eject a cd from the drive. i have tried to eject using the button and in my computer. in device manager it says the device is fine. any ideas?? there isnt an manual eject hole for the paperclip...
Shut down the PC, for 2min, then turn on, this is either a hardware or software problem. Software meaning that it is unable to execute the command to eject, shutting down and turning on may resolve this problem. Or hardware is the sence that the disk is Physicaly stuck in which case you would need some one with the know how to remove the disk without damaging the components within.
Your timely rating of this soloution is much appreciated.
Thanks
Nov 01, 2010 | Acer Aspire Z5600 PC Desktop
My acer aspire l100 keeps shutting off. it sometimes will stay on for like two minutes but most of the time it shuts down after like 30 seconds. it works fine in safe mode. most of the time it shuts off...
this seems like a software issue . if you can not run your system but ift works fine in safe mode try to run a system restore from factory disks and see where that gets you,
May 14, 2010 | Acer Aspire L100 PC Desktop
My friends Acer Aspire M5641 has a black screen and won't boot up. I cleaned out all the dust and even tried to boot using the Windows Vista recovery disk but no luck. She hasn't made any major changes...
Sir,
there could be many problems in this case such as your motherboard not recieving Power , RAM have got fired, or Motherboards BIOS is failur it can be check by removing Ram if the problem is of ram.
Nov 10, 2009 | Acer Aspire M5641 PC Desktop
Systems shut down
Sounds like a software error, Try using system restore to set back the pc to an earlier time. Also try starting up in safe mode and uninstall any software that you may have installed.
Sep 28, 2009 | Acer Aspire One Netbook 8.9" Notebook
Door spring fell off I can not get it back on to work
Not much I can help with here, except maybe grab two tweezers or two small needle nose pliers and try to get that spring in there. Will take a try or two, but you'll get it.
May 31, 2009 | Acer Aspire™ T180 PC Desktop
Pc wont power down
Sounds like a software application is not allowing machine to shut down. Try using the task manager to shut down all applications and processes manually, then try the shutdown option. If this works you will have to go through software apps one by one until you find the culprit. Hope this helps.
Dec 21, 2008 | Acer Aspire T120 PC Desktop
Computers & Internet Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
