Question about Nokia 1600 Cellular Phone
Power-on suddenly stops powering after charging battery externally
YOU NEED TO REPROGRAM YOUR CELLPHONE
Posted on Mar 01, 2009
My battery will not charge. Have tried different batteries and chargers. Works fine on mains power. Any ideas please? Roger
sounds like to me you have a bad connection in the battery terminals. try cleaning the contacts with a Emery stick.
Nov 08, 2014 | Acer Aspire 3810T 4810T 5810T
Acer Aspire battery level suddenly drops 80 %
Have you seen inside a laptop battery, it's not just a battery. It also has control circuitry inside, could be that. Not usually repairble but you can do some makes of battery. See here:Circuit.
Personally I would buy a new battery.
Jan 27, 2012 | Computers & Internet
My Canon ZR950 stopped working all of a sudden. Won't power on with battery (charged externally) or AC power cord. Tape holder doesn't even pop up and open. It won't do ANYTHING. It was...
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Jul 16, 2011 | Canon VIXIA HV30 DV Camcorder
Toshiba SATELLITE A205-S4577 CORE 2 DUO INTEL. When conected to the external power supply the notebook suddenly interrupts its functioning and it is necessary to do a hard power off, becouse nothing more...
- possible problem with the AC power supply
- try using a different AC adapter. if issue persist try flashing the BIOS. if issue still persist then have the motherboard checked out.
Mar 29, 2011 | Toshiba A205-S4577 Notebook
Kodak digital camera not charging/ indicator not shown while plug in charger
Either an error occurred during charging, an AC power disruption occurred during charging, the wrong AC power adapter is being used, batteries are over- discharged, batteries are defective, or no batteries are installed in the camera.
Try charging the batteries a couple of times. If that fails, try charging the batteries in an external charger. If the batteries still will not charge, purchase new batteries and try again
Jun 30, 2010 | Kodak EASYSHARE M1063 Digital Camera
Laptop died suddenly and is not charging
Take the battery out and discharge the capacitors by holding down the power button for 15 seconds. plug in the charger without the battery in to see if you get a charge light. If you do, replace battery and plug in charger and power on laptop. If this does not work, you may have to pull the cmos battery for 15 minutes and try it again.
Oct 03, 2009 | Computers & Internet
DCR-HC42 doesnt work with batteries
I recommend you taking this into the nearest BatteriesPlus...they can test your batteries to make sure they are good. They can also help figure out the problem. www.batteriesplus.com
Feb 18, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
My T42 suddenly wont recharge the battery or wrk off mainsadapter
If the Laptop wont work off the power adepter, it also will not charge. The adepter could be bad (even if showing a power light) or the connector on the laptop could be broken. The best test is to take the battery out, attach the power adepter and try to start the computer if it starts, your battery is at fault. If nothing, suspect eh charger first. Be sure the pin on the Laptop power connector isn't bent or broken.
Jan 04, 2009 | IBM ThinkPad T42 Notebook
My garmin 340 suddenly stopped working
Ummmmm "Low battery"....... not too hard to figure out. You need to charge it for several hours. If the battery is low it WILL go out on you and during that time, the battery may recover enough to come on briefly then go off again. Please charge your battery!
- Jim
Sep 13, 2008 | GPS
Wont recognise battery
Those may have 1 or 2 different problems. Cold Solder joint on Mobo. Bad DC Power Jack. 1: if it is the Cold Solder, you can reflow the solder and be done with it. 2: if it is the DC power jack, It should be replaced. For simplicity lets call them DC(A) and DC(B) There are 3 connections to it. Gnd, DC (A), and DC (B). When the powersupply is plugged in, contacts (A) touch to send +DC to the laptop. (B) is open. When the laptop is using battery power, contacts (B) touch to send power from the battery through the system. Over a period of time (inserting and removing the DC Power Cord), the contacts become fatigued, or oxidized and the DC(B) never closes - so it won't work from DC Battery. RATE ME - if it helps
Nov 26, 2006 | Compaq Refurbished Notebooks: Armada M700...
Nokia 1600 Cellular Phone Logo
27 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
