Question about Apple Cinema HD 23" LCD Monitor
The upper half of my Apple 23" Cinema HD (ADC) display has suddenly become relatively dim. The power light on the lower front is now flashing the following sequence repeatedly... short-short-long. What do you you suspect has occurred? Allen Z.
  • toothmover Mar 01, 2009
    Ok. So if it is a lamp outage, what are my repair options? Are you very familiar with this Apple display? I am pretty handy. If I purchase a new lamp, is it reasonably simple to do a self repair? If not, can you recommend a reputable, and affordable service, other than apple?
    Thank you. Allen Z.
  • toothmover Mar 02, 2009
    Dear Suterman--- Thank you so much! I couldn't believe it. I awoke this morning, and did exactly what you said, and all seems to be working just fine. I only hope the problem doesn't recur too soon. I guess the best repair is sometimes to shut down, unplug and reinsert, restart after a dormant period. How sure were you that this would be the solution to my problem??? Just curious! Thanks again, for the best $10. spent. I am indeed impressed with this service. Best regards---DrZ
  • 59 Answers
If you want to try an inverter board the only one I have found is at http://www.welovemacs.com/9225581.html
Also here is a PDF file to help you trouble shoot whether it is the inverter board or the backlight.
http://www.retrocomputing.net/info/siti/ManualiApple/cinema_display_23.pdf
Check page 13 of the PDF.
Hope this helps.
Posted on Mar 01, 2009
  • Tim Crosslin Mar 01, 2009
    Probably to find the back light if it is bad, get the make and model of the monitor inside and then search for them.
    Also the PDF will tell you how to remove the backlights, on page 8.
  • 158 Answers
Hello,I see you are having a problem with your monitor. You may want to turn it off, Then disconnect it. Then reconnect everthing again and power your system back up.
  • suterman
    suterman Mar 02, 2009
    Thank you, I was just trying what I have done in the past . And I also had positive results. I havent anymore problems with mine.
  • 2,296 Answers
The darker area on the top could be a light failure inside the screen. LCDs have 2 lights inside to illuminate the screen, if one fails then there will not be enough light causing the screen to go darker.
  • Jaime Hernandez Mar 01, 2009
    The PDF file provided by techigs64 shows exactly how to access the backlight bulbs. I would suggest to call apple to buy the replacement parts.
    Good Luck.
    Brigadier General:
  • 8,619 Answers
Hi!
Its the issue with the inverter board. Try swithing it off for half an hour and then try to switch it back on.
  • 1 more comment
  • Rylee Smith
    Rylee Smith Mar 01, 2009
    If its under warranty, then get the inverter board checked as the top backlight bulbs is not working or has burned out.
    Please ask for further clarifications.
    Thanks
    Rylee
  • Rylee Smith
    Alos try and resetting the video card by restarting the computer while resetting the video card (holding down Command+Option+A+V), and when it finished the screen will be back to normal.
  • Rylee Smith
    I would recommend you the apple people as sometimes the monitor doesn't need that light replacement, they can fix it without replacing and will charge you around $60. Apple repair-
    Apple Repair 1-800-APLCARE
    But, even after you reset your monitor and it still doesn't work then call "Monitor Experts" 1-800-499-777(They will fix the light for around $150-180)
    Thanks
    Rylee
Blinking light on 20 inch apple display
Blinking light on Apple cinema display usually indicates insufficient power from the power supply. Test it with another power supply from ANY cinema display (23" and 27" power supplies are ok to test with).
Feb 03, 2014 | Apple Cinema HD 30" LCD Monitor
Apple cinema display 23"
Hello!
Please do and verify any fuse blownout in the inlet of the power from the wall, if it is not visible then maybe you open the the back cover and try to see any parts that has error or blown. you should replace it with genuine replacement parts. however it hard to do this by a novice tech, My suggestion is to bring the unit to the nearest service center maybe the unit got warranty service or else maybe its a cheap or resonable cost.
may this help!
best regards, melnavz
Mar 03, 2008 | Apple Cinema Display 23" HD Monitor
My 23" Apple cinema display (2002) has black screen and code flashes three short flashes. How do I find out if the monitor is dead or the power supply?
The only way to test is to use a known working power supply or known working cinema display with the parts you already have.
Dec 11, 2012 | Apple Cinema Display 23" HD Monitor
Can someone help me a circuit diagram for the apple 23" HD monitor
http://tim.id.au/laptops/apple/displays/cinema_hd_display_23.pdf
May 26, 2012 | Apple A1082 CINEMA DISPLAY 23" LCD Monitor
Power connector on cinema display is damaged. Can it be replaced?
Hello, GREAT NEWS!!! Yes you can replace it. Try going onto Ebay and punch in: A1097 Apple cinema display power ac adapter 90W 23" LCD.
May 05, 2010 | Apple Cinema Display 23" HD Monitor
Vertical red line suddenly appeared about 3" from right side
Download free Service Source Apple Cinema HD Display 23′ LCD (ADC).pdf (20 pages pdf file, 1 MB). (You have to add a .pdf extension to this file, in order to display this service manual correctly.)
OK that link will get you a a service and repair manual, use this to sort out your problem. Right click on the blue link above, and save as, remember to add .pdf.
May 01, 2010 | Apple Cinema Display 23" HD Monitor
Apple 23 monitor 3 blinks and then pause, top screen is dim.
I have an older 20" display. I have had this same problem on occasion, and coincidentally, just experienced it again this morning. It seems to occur after I do an OS update. I powered down the computer, disconnected the display, reconnected by pushing firmly into place, then powered up. The flashing stopped and the display works fine. You might have a different problem, but that simple solution worked for me.
Apr 04, 2009 | Apple Cinema Display 23" HD Monitor
Apple 23" cinema display
thats supposed to mean theres a faulty powerbrick, however i have the same problem on mine and replacing that didn't solve it
Oct 28, 2008 | Apple Cinema Display 23" HD Monitor
Apple 23" Cinema HD Display went off
Hey - I just got done with 30 minutes of trying my cinema HD on my macbook pro and plugging and unplugging. When I plugged it into an extension cord in another socket the monitor started right up. I've had this configuration in my office for years with no problem...until today. Did mac send us a system upgrade that caused a problem with the monitor's power source???? Good luck!!!!
Jul 28, 2008 | Apple Cinema Display 23" HD Monitor
Apple Cinema HD 23" LCD Monitor Logo
177 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
MarkMAlford
MarkMAlford
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
