Question about Sony RDR-VX500 DVD Recorder/VCR
Sony rdr vx500 - can not get title list for DVDs
Every time i try to record to a DVD-R, i keep getting the same message, after i stop recording - No Title List Found, will not record to a DVD
SOURCE: failure to record on -R DVDs
DVD-Rs do work with the RDR-VX500 ...... I had not recorded on mine for a few months after I ran out of the last batch ....... then I tried recording on the newer Sony DVD-Rs I had ...... would not record on DVD-R ..... turns out the instructions say the recorder will not work with any DVDs faster than 8x .... It looks like it's recording but it doesn't ..... then I noticed the newer DVDs were 16x ...... found an old 8x and tried it and it works fine ..... turns out the unit won't record slower on a 16x, it just won't record at all ...... get 8x and you'll be ok
Posted on Sep 30, 2008
  • 643 Answers
SOURCE: Sony RDR-GX315 DVD 3 problem
sounds like your laser is getting weak. repair is usually not economical. laser is about 90% the cost of the unit. hope this helps if it still plays but not record. keep it as strictly playback unit.
Posted on Jun 04, 2009
  • 27 Answers
Make sure your Sony input signal is on L1 or L3 (the inputs in back of recorder) or on L2 which is for inputs for cameras(located in front).Once you get a signal, you're where you need to be. Choose your recording mode for recording speed (pull down the flap on the remote control for this button and also the input button).
Choose from between1 hour and six hours. To archive really important stuff, stick with the first 3 speeds. TV recording can be on 3, 4 or 6 hour mode.
Push the record/pause button once. This will put the recorder into the record/pause mode and then it awaits you pushing it again to start recording immediately. Just pushing record will force the machine into a 3 to five second delay before actually recording anything so you might mess up and miss the first few seconds of your input. Suggest you use a dvr-rw or dvd+rw to practice on.
When your recording is done, just push the pause again. It stops recording but allows you to add more on to the first recording without starting a new chapter if you want. Just continue to release the pause button to continue.
If you are satisfied that you are finished, then push the pause button to stop recording. Wait for the info to be written(flashing message on screen). When it stops, you may play the dvd.
Notice- since the dvd has not been FINALIZED, you may only play it back on this unit without finalizing. It will not play on other dvd players unless you finalize it first.
To finalize, look on remote for the TOOL button. Press it once. Now push DISC INFO once. Use arrow keys and enter button on remote for the following. Scroll down to FINALIZE and press enter.
Use arrow keys to scroll to OK. push the ENTER button. Finalizing should take between 30 seconds and 2 minutes.
Warning- if titles or chapters are to typed in, it must be done BEFORE finalizing. Finalizing afterwards cannot be done.
Erasing can be done in part or all if using an RW+ or RW- disc
Posted on Dec 28, 2009
  • 19396 Answers
SOURCE: Sony rdr-hx715 says cannot record this
The DVDR may be tuned on a different input. Ensure that the DVR is tuned on the TV input. Press CH- until you reach input line if the DVR is tuned on TV , otherwise the DVR will try recording from its own antenna input on one of the channels, that probably are not programmed on DVR internal tuner.
Here the manual.
Posted on Sep 04, 2010
  • 11800 Answers
SOURCE: Hi, I have a sony
The hard disk inside it is failing - mechanical failure. This is unfixable, the hard disk must be replaced. Luckily a new one costs less than $25, can be bought at every IT shop and the procedure of replacing it is very simple and fast - less than half an hour: you open the case of the recorder, you unscrew the screws that keep it in place, you unplug the 2 cables that connect to the hdd and you take it out; the install is in reverse.
Posted on May 19, 2011
I can not get my DVD to play after dubbing. A message comes up, no title.
dvd+rw is garbage, organic dye in the layers breaks down fast, always use dvd-r. dvd-rw also has compatible reading problems with many dvd players, hope that helps. also you need to make sure it is finalized for another dvd player to read it
Mar 19, 2014 | Sony RDR-VX560 DVD Recorder/VCR
I recently purchased the Toshiba DR570KU DVD recorder. I live and purchased this machine on a small Caribbean Island,and with respect to local people they have no technical knowledge of what they are...
Hi -
I'll try to explain without confusing you any further, but if anything doesn't make sense, please let me know. The instructions on page 79 are contradictory, which doesn't help very much. The upper part of the page suggests you can create extra space on a DVD+RW disc by deleting titles, while the lower part, in the grey box, states you cannot. The bottom part is actually correct.
I'll split this into two sections - blank/unused and used discs then explore a few scenarios.
Blank/unused discs
A DVD+RW is typically 4.7GB and will record approx. 2 hours of video in SP mode or 4 hours inLP mode. If you record more than one programme, they will appear consecutively in the disc editing menu, and shown as numbered blocks in the Title List. The last block shown will always be 'EMPTY', but the actual size of this block can be all or none of the total capacity of the disc.
If you insert a blank DVD+RW disc into the machine and view the title list, you will see this:
Although you can't 'record' to a block labelled EMPTY, this doesn't mean you cannot record to this disc. The blank space on the disc precedes the block labelled as 'EMPTY'.
If you then record one programme of 1 hour duration in SP mode. the title list will look like this:
Once again, although you can't 'record' to the block labelled EMPTY, this doesn't mean this disc is full or that you cannot record anything else on it. The next programme recorder will appear between title 1 and the 'empty' block - as long as there is sufficient space on the disc remaining to record the programme.
If you then record a second programme of 1 hour duration in SP mode. the title list will look like this:
This disc is now full as 2 hours of video has been recorded in SP mode. However, if you'd only recorded 1 hour in total for these 2 programmes, you would still be able to record another hour of video in SP to this disc. The additional programmes would appear between the last numbered title and the 'empty' block - until the disc is full.
The empty block is always present and you cannot 'get rid of it', but it doesn't mean the disc is full or cannot be recorded on.
Hopefully, this goes some way to explaining it, but I still need need to explain what happens with used / full discs when you want to delete programmes and re-record.
There is a maximum length for messages posted on FixYa and I may be getting close to this, so rather than break off in mid-flow, I will continue the explanation for used discs in another message below this one. I will do this right now, but it will probably take me 20 minutes or so to write part 2, so keep checking back. It will be less confusing if you hold any questions until I've written part 2, but I will be happy to answer any after that.
May 02, 2011 | Toshiba DR570 DVD Recorder
Jun 04, 2009 | Sony RDR-VX530 DVD Recorder/VCR
"Invalid Video Found" HDR-CX7 and VRD-MC5 DVD Recorder
The same happend to me. The camera contains informations of videofiles, which are no more present on the camera (were deleted from a computer). You are not able to record in full disk mode, or any other mode, which includes these videos. These missing files can be easily recognised, as the camcorder is not able to play them. Try to get rid of these "files", or ommit them from the recording list.
Dec 27, 2008 | Sony DVDirect VRD-MC3 DVD Recorder
I cannot finalize it keeps on saying no title list.
Are you absolutely sure there are recordings on that disc?The message means the recorder can´t find any. If you have a chance and it´s a VR-disc, try playing it on another player that is known to be able to play unfinalized VRs. If it was recorded in video mode there´s nothing you can do. If the material is of great importance turn to data retrieval professionals.
Dec 12, 2008 | Samsung DVDR120 DVD Recorder
DVD Menu selection not available from Setup Menu
I don't have movies from premium channels, but do have cable HD channels. When I got the message re not recording in +VR, I copied from DVR to HD in PhilipsDVD-R and then dubbed to DVD.
Dec 05, 2008 | Televison & Video
Deleting a title after recording, before finalizing
Usually, nothing can be deleted after finalizing. But deleting a brief title donesn't change the remaining time. Deleting a long one does eats up some of the DVD time...
Nov 15, 2008 | Panasonic DMR-ES10 DVD Recorder
Recording problem
I have had two of these recorders, Using only Sony + discs or rewriteables is my solution, I will not use any thing else. It may work 1-3 times on others brands then start throwing coasters.
As to renaming, on my model I pull up the tiltle menu then select Try using rewriteables for the other problem as well My model is a little older and lets me take disc out without finalizing then when inserting select title, hit edit on remote and select rename. Maybe if you can skip the finalizing (as with rewritables it will help
Apr 01, 2008 | iLO DVDR05 DVD Recorder
mine too. i found a firmware update that seems to have helped (i tried recording about 10x after this update and it's ok so far).
Oct 24, 2007 | Panasonic DMR-E55 DVD Recorder
Sony RDR-VX500 DVD Recorder/VCR Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
