Question about Sony Walkman NWZ-S616F MP3 Player
My MP3 player will not turn off
Player battery died and after I plugged it into my computer it started up and will not turn off. Start up menu has stayed on since connection to computer. What can be done besides reseting the player.
HOLD THE BTTON DOWN UNTIL IT TURNS OFF. IF THAT DON'T WORK TAKE THE BATERY OUT AND PUT IT BACK IN AND TRY AGAIN. IF IT HELPS ONE OR THE OTHER SEND A MESSAGE BACK ON HOW TO DOWNLOAD SONGS ON TO AN MP3 PLAYER,I ASKED THAT BECAUSE I NEED HELP TO DO THAT SO GOOD-BYE.AND I WANT TO KNOW WHAT YOUR NAME IS MINE IS WELL JOE.
Posted on Mar 01, 2009
Can't make the player turn on. What do I do?
First try and reset the player.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
If that does not work try this,
Remove the battery - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
STEP 1 - Connect the device to the computer
1. Remove the battery from the player's battery compartment.
2. Put the hold/lock switch to lock.
3. Plug in your device to the computer.
STEP 2 - Format the device
1. Double-click My Computer.
2. Right-click on the player, which might show up as a Removable Drive, select Format.
3. Click Start.
4. Click OK when a "Format Complete" dialog appears.
5. Click Close.
Nov 12, 2010 | SanDisk Sansa m240 MP3 Player
How do I download Pictures to MP3?
A generic procedure is :-
  1. Turn on your computer. Plug the USB cable that came with your MP3 player into an open USB port on your computer.
  2. Step 2 Turn off your MP3 player and plug the other end of the USB cable into the USB port located on top of the player. Turn on the player.
  3. Step 3 On your computer, right-click the pictures you want and select "Copy" from the menu that appears.
  4. Step 4 Double-click the "My Computer" icon on your computer. Double-click "MP3 player " or ' MP3 Device" in the "My Computer" window.
  5. Step 5 Open the "Pictures" folder. Right-click and select "Paste" from the menu that appears.
  6. Step 6 Let the files copy. Click the "Safely Remove Device" icon located on the left side of the Start toolbar at the bottom of your screen.
  7. Step 7 Click "Safely Remove USB Storage Device." Wait for a message to appear that says it is safe to remove the device, and then unplug the USB cable from your computer and your MP3 player.
Hope i helped you.
Thanks.
Aug 30, 2009 | Audio Players & Recorders
Computer doesn't recognize MP3 player -
I think I have a solution. First you turn on the MP3 Player and then go to the menu. Go down to settings. Then, go to USB. Go down to "MSC" and hit the middle button. It should take you back to the settings menu. That means you successfully changed that setting. Now plug the MP3 Player back into the computer and open up "My Computer." It should show up. I hope this helps!
Jul 24, 2008 | SanDisk Sansa m240 MP3 Player
Flashing start- up menu
Reset the player and try replugging it to the computer - see if you get better results.
Jun 16, 2008 | iLO (2 GB) MP3 Player
Ilo mp3 player
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Jan 13, 2008 | iLO (2 GB) MP3 Player
XOvision Styler X120AUD2GB MP3 player problems
for notforreal, did you firmware upgrade? if you did, here the link to fix the problem,
For X120AUD2GB http://www.xovision.com/downloads/X120AUD2GB%20UPGRADE%20SOFTWARE.zip
For X120AUD4GB
http://www.xovision.com/downloads/X120AUD4GB%20UPGRADE%20SOFTWARE.zip
For songs that got deleted, or just simply disappear
is the file system of your player FAT32? if yes just format it in FAT. this will solved the problem of losing music.
1) Plug your Player to usb port of your computer
2) Wait until it is recognizes as flash drive
3) Go to My Computer, look for the removable disk
4)Right click, then click format, window will pop up, on file format, choose FAT
5) click start, wait until finish formatting.
6) then you can now start using your player.
Dec 30, 2007 | Audio Players & Recorders
I CAN'T SEE MY MP3 PLAYER IM COMPUTER. I've already used windows media player, but nothing is the same. I've lost the cd of my mp3 player. Can you help me please!?!? Thanks in advance.
From my understanding your computer isn't detecting you're mp3 player in Windows media player. If you go to the start menu on your desktop click on my computer. There will be a list of items there. You mp3 might be there. You're UBS port might be broken so try connecting it to the computer through a different one. Also the UBS port on your mp3 might be broken.
Dec 30, 2007 | Samsung YP-K3 MP3 Player
Not turning on
Hi there. Your player may be experiencing some temporary power problems which may be corrected using the following procedures: (1) Remove the battery, then press and hold the "Menu" button for 30 seconds to drain the excess electrical charge off the player (2) Insert an unused battery and try to turn it on again (3) If this does not work, repeat the same process but this time, press and hold the "Menu" button longer (45 seconds to 1 minute). Insert an unused battery and try to turn it on again Another way would be to format the player. But before formatting the player, switch the player to "MSC" mode (to allow the computer to recognize the player as a "Flash Drive") by enabling the "Hold" switch (slide the Hold switch to expose the "orange-colored surface") (1) Plug the player to your computer (2) In Windows Explorer, locate the player (it would be assigned a drive letter) (3) Right-click on the drive letter corresponding to the M240, then select "Format" (4) On the "Format" window, make sure you select "FAT" as its File System type (5) CLick "Start"to begin the format process. (6) Unplug the player, disable the Hold switch, then try to turn the player on.
May 15, 2007 | SanDisk Sansa m240 MP3 Player
My iBulldog won't turn on
It's on hold or your batterie died. It eats batteries quickly, try a new batterie.
Feb 13, 2007 | i-Bulldog IMP-90 MP3 Player
Sony Walkman NWZ-S616F MP3 Player Logo
73 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
