Question about Garden
Tiller need to be repaired i need manuel and parts
I have a 6 three point hitch long mfg tillew moldle # 1542 seriel # 1151 where can i find repair manual and parts
  • davevigil Mar 01, 2009
    it tiller not tillew
Looking for a"Long" brand garden tiller model # 1542 for parts.
Posted on Sep 15, 2010
Three point hitch when up all the way the pump continues to. Pump
Springs, or valve seats in the control valve need repair. Or at least my wild guess, with some understanding of hydraulics, in general.
Mar 25, 2015 | John Deere Garden
The three point hitch up down lever moves as tractor is moving, handle/lever very loose.how can i tighten it up?,
I'd try to get a repair manual. MFG customer service may also be helpful, email or call.
manualslib.com may have it. There may be a locking nut that has come loose, and therefore the nut that holds it tight has also come loose. Follow the lever to where it attaches at a pivot point. Look for loose and nut to tighten.
Mar 18, 2015 | Garden
I am needing the seriel number for ariens rocket
-If you need only the rope, you don't need the series number. Just go to Lowe or Home depot and buy 1/8" Dia at 4 feet. Unless you need the whole assembly kit. If so go to where you get it from.
Good luck.
Mai
Aug 27, 2014 | Garden
How to adjust mahindra 5005 three point hitch down pressure?
1 Draft sensing lever in wrong position
Move lever to "light" position.
2 Rate-of-drop too slow
Adjust rate-of-drop valve.
3 Center link on upper front hole
Move center link to lower hole.
4 Draft control out of adjustment
Refer to service manual for adjustment procedure.
5 Internal mechanical interference with load control linkage
Refer to service manual to find interference, or possibly linkage coming apart.
6 Load control shaft or tube broken or bent
Replace load control shaft or tube. Refer to service manual.
7 Load sensing pin malfunctioning, or bad connections - only applies to newer tractors
Replace load sensing pin, repair faulty connections. Refer to service manual.
Aug 13, 2014 | Garden
Manuel 18hp johnson
sad to say but a NEW manual can not be bought. OMC only supplied them for a couple years after mfg.best bet is get a clymers repair manual and hope for the best . best bet is take it to a dealer when repairs are needed.
Apr 09, 2010 | Boating
Replace belts on Montgomery Ward rear tine rototiller Model number GIL39012B need diagram
Go here and you can download a free manual for your machine.
http://lawnandgarden.manualsonline.com/manuals/mfg/montgomery_ward/tmo39083a.html
Oct 24, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Three point hitch on 2020 Jogn Deere Tractor will not raise.
The three point hitch raises with hydraulic pressure. When the hitch will not raise the first thing to check is the hydraulic fluid level. If it is low add hydraulic fluid to the proper level as stated in the owner manual.
Jun 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Need free repair manual down load on Troy Bilt Junior 500 30 82
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
Free manuals for Troybilt here
May 17, 2009 | Troy-Bilt Pony Garden Tiller
Craftsman 6 hp chipper/shredder model # 247.796891 + need service/ user manuel
that model is showing its a 5 h.p. the manuels are no longer available i can help with parts if needed
Apr 29, 2009 | Craftsman Gas Mini - Tiller/Edger
Rototiller transmission
I am having transmission problem (loud noises). I am looking for a repair manuel for a roper rear tine tiller. Model RT150GR chain drive.
Mar 27, 2009 | Craftsman Garden
Garden Logo
249 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
