Question about LG 24 in. LDS 5811 Built-in Dishwasher
Lg 5811 built-in LE code flashing checked wiring behind dr seemed ok
  • 1,543 Answers
If you have separated the door panels and confirmed that none of the wiring is embedded in the insulation mastic, your next step is to take the covers off the sump area in the bottom of the dishwasher to see if anything (like dental floss or twist ties) is wrapped around the motor shaft. (note: the cutter blade on the end of the motor shaft is held on with a screw that has a left hand thread) If all was clear, replace the motor. To replace motor, pull dishwasher out of cabinet and lay on its side for easy replacement from this point.
Posted on Mar 01, 2009
LE CODE ON LG DISHWASHER
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective.
Aug 14, 2014 | LG 24 in. LDS 5811 Built-in Dishwasher
What does the display 'LE' mean on the LG built in dishwasher?
motor error or broken wire. look near the door and make sure there are no broken wires
Dec 03, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Motor keeps trying to start then after several tries unit shuts down. LE id on the display.
hello,
what this code indicate that there is an unlock object i.e the door need to be properly close.
hope this help?
thanks
Oct 23, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
LG DISHWASHER, STOPS WORKING AND DISPLAYS LE. WHAT DOES THIS MEAN
LE is a Motor error
Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked.
Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB
Sep 07, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
AE displayed on LG dishwasher
Please look one more time. The LG LDS 5811 dishwasher error codes are:
IE Error
OE Error
FE Error
E1 Error
HE Error
tE Error
It would also be helpful to know what happens when this error code displays. Please post back here, OK?
Thanks.
Apr 16, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
I get error code le on LG dishwasher.
hi,
le means locked motor disassemble the filter and work your way down to the macerator(steel chopper blade) remove it and see if the side labeled "this side up" is really up, its in english... dont think the chinese labourers paid attention to the warning cause i have seen alot that were wrong way
if it was installed correctly order the complete motor/sump assembly btw you do know LG d/w came with a 2 year warranty right? and some of the water distribution system had a longer limited warranty
read your manual, it states warranty, then price the part, then call warranty depot to ask them their service call and labour to install motor/sump
This part taken from a LG repair manual:
(Display Condition LE = Motor Error
locked.
locked.
Remedy:
Replace the PCB.)
good luck.........
Mar 12, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Dishwasher
The LE code indicates motor failure (or intermittent problem with motor). Based on what Ive read their support sucks, so sory to be bearer of bad news...
Nov 01, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Era codes
The PF code means that there is a power problem with your unit. Make sure that you're not having issues with your outlet.  Check the connection at the junction box to make sure they're good and tight.  If both of those check out ok, open the front panel of the dishwasher and check the wiring harness there.  About 1/3 of the way up from the bottom of the door, inspect the wire harness for any signs of cracks or breaks in the wire.  Repair the damaged wires and that should take care of your PF issues.
Jun 24, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG 24 in. LDS 5811 Built-in Dishwasher Logo
124 people viewed this question
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
