Question about Kenmore 44102 Front Load Washer
48102 kenmore washer drains but more on floor than thru drain pipe
    Scholar:
  • 106 Answers
You only have to look under where the hose might have come loose, refit. Check out your filter also.
Posted on Mar 01, 2009
What is best way to have my new Kenmore Elite Top-Loading washer (Model 796.3162) drain into a high pipe 7 feet from floor?
Nope, the drain pipe can be no higher than the Washing machine itself, the pump's to weak will not carry the water
Nov 19, 2014 | Kenmore Washing Machines
What height should the washer be at for proper draining
Normally washers sit on the floor and are drained, by a 'bent pipe', either into their own waste pipe or into a shared sink system. The higher the waste pipe is the harder the drain pump has to work to push the water out. Normally this should not be a problem as the pump should be powerful enough for the task!
So- the answer really is that it is not the washer height which matters but the waste height- and even then not much!
Hope this answers your question.
Cheers,
John C
Feb 09, 2011 | Kenmore 43142 Front Load Washer
I have a Kenmore 500 top load washer that doesn't hold water. As it is filling for the wash cycle all the water runs down the drain
The drain hose outlet must be higher than the 'full' water level in the tub or the water will syphon out until the tub water equals the hose height. If the drain system you are using for the washer is floor level, then you need to install a vertical pipe (1-1/2" minimum) to place the hose end into at the top and it should eject the water through a 90 degree elbow onto the floor at the bottom. There are more elegant solutions, but this will stop the tub from self-draining. Good luck!
Aug 05, 2010 | Kenmore 22422 Top Load Washer
My washer wont drain it goes thru all the cycles but wont drain. at first with clothes in it it would drain onto the ground and not thru the drain pipe. took the front cover off to see where it was leaking...
Sounds like the drain pump has failed. Try to turn the impeller to see if it is bound-up. It may just be debris blocking the rotation of the motor. Is there a filter that has plugged?
Feb 10, 2010 | Kenmore 98702 Stacked Washer/Dryer
My washer drain pipe is overflowing on my floor
Sounds like your drain pipe is restricted or clogged. Try using a "Pipe Snake" to unclog.
Jul 26, 2009 | Kenmore 500 6953 Dryer
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Just got a new washer now my drain is overflowing
ok thats easy enough,,i dont do plumbing but i know appliances,,,go to one of your do it yourself home improvement places and purchase a plastic sink,,,sink has to hold 16 gallons ..or more,,add it to your pipe in the floor and let the water drain into tub first...the most your unit will drain at any one time is 14 gallons,,wash or rinse,,..onthejob...also you can place this truff anywhere with some pvc,,,hold thing might run 49.99..tops
Jan 21, 2009 | Kenmore Elite 45986 Front Load Washer
Water won't drain thru
you need to clean the drain pipe, maybe draino or call a plumber to snake it out.
Aug 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 44102 Front Load Washer Logo
492 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
