Question about Oster 4134 / 4126 Classic Beehive Work Top Blender
Oseterizer 2spd Blender | Proper order of hardware related to fan
Received blender for Christmas 2008, and used regularly until the fan and hardware loosened from the vibration of the blender. Want to make sure hardware and fan are replaced properly. No information on proper order of harware in manual or online. Do not want to send for repair due to simple task. Any information to validate would be great! Thanks!
GR
  • 4 Answers
You should have four parts:
Shiny washer
Fan
Black spring-washer
Bolt
They assemble onto the driveshaft in that order.
Posted on Mar 01, 2009
Tip
The best way to clean your blender
I used to hate using my blender. I could make great smoothies or hearty soups but after I was done, I hated to clean it. The blender would be covered in small seeds or other small pieces of food that were stuck on. Plus, I'd be terrified of the cutting myself on the sharp blade (even when the blender was unplugged.)
So here is what you do:
1. Boil enough water to fill the blender.
2. Put a few drops of soap in the blender and plug it in.
3. Pour the boiling water over the soap in the blender, cover it and turn on.
You can let the blender run for two minutes, until it is clean or until all the little pieces are removed from the sides.
4. Rinse out with water and repeat if necessary.
And there you have it, using a blender just became a little easier.. since the cleanup is no longer a hassle.
on Dec 26, 2013 | Blenders
The coleman rechargable blender not blending
Subject: Rechargeable Portable Blender Model No. 850-870
I was given one of these blenders for Christmas. I charged it through 3
cycles, used it once and the battery was dead. Charged it through another 5
charge cycles and used it once only to then have another dead battery. I
have put it through at least another 8 charge cycles, and it indicates a
DEAD battery. I have managed to blend two (2) 3/4 full pitchers in total. On
trying to start it now the green light 'flickers' quickly on and shuts down.
This is a totally useless device.
I would like to return it for a full refund, including shipping.
Dec 21, 2009 | Coleman 850-870 Single-Speed Blender
Waring pro wpb blender emit burning smoke and smell when i was blending ...
Obviously the motor winding is burned out. it needs to be rewound. This is can be done only by repair men who regularly wind motors.
All blenders have one thing in common. They draw more than rated current when running slow. If u continued using it inspite of noticing low speed then the it results in burnt motor winding as is the case now.
Also the blenders should not be run on no load, which will cause meahanical damage to fan and bearings.
Oct 16, 2009 | Waring WPB 01 / 04 / 05 / 09 Professional...
Jack La Lanne's Health Master 100
First determine..if it is indeed the motor that is fried. Do this by not using the caraffe. Plug in the motor and run it by itself. If it runs fine without smoking again..It is the caraffe that is defective.
If its the motor you are out of luck completely. Jack Lalanne is out of business.
If it is the caraffe..which I suspect it is not...oil the rim of the bearing that is on the outside of your caraffe ..it surrounds the knurled part that is inserted into the blender...even if you are able to get the motor repaired..get in the habit of oiling the caraffe bearing after each time you use it. If you dont it will fail within months to a year of use
Lalanne had they made in China..and using unsealed bearinga that rust out and the contents of the blender come out!! So I discovere dthat oiling that part each time after use..keeps my blender running smoothly.
You might want to take yoru motor to a small appliance repairman..he might find something simple happened.. like a loose wire connection inside! If he does...you have a simple solution and a motor that works!
Remember to oil the bearing a couple drops each time after use...and if yoru caraffe ever fails you can buy a new one..( Oil that one too!) at Cooking Toys..you can google for the address
gmcgeary@gmail.com
Jan 06, 2009 | Jack Lalanne Health Master 100 Blender...
Replacing rubber drive coupling
My coupler was split in two, and I couldn't screw it off. I had to do the following:
1. Take the blender apart (mine had 2 screws on the bottom). 2. Remove the motor housing from the blender (mine was loose from removing the two screws earlier). 3. Remove the fan by removing the fan nut. 4. Take apart the motor housing. Mine had two machine screws with 1/4" hex heads holding a bracket that tied the two ends together. Once those two screws are removed, you can take the motor out of the housing. Be careful on the fan end of the motor, because it's got two spring loaded brushes that will come together once the motor is pulled through. 6. Once you have the motor out of the housing, you'll have something to grab onto so you'll be able to unscrew the broken coupler. I used a pair of channel locks and gently grasped the motor body, and then just used a regular pair of pliers to grab the broken coupler. It's regular thread (lefty lucy righty tighty), so twist accordingly.
Once you have the coupler off, just put everything back together. The hardest part is holding apart the spring loaded brushes while you push the fan end of the motor shaft back through the motor housing.
Took me about 20 minutes to do everything.
Good luck.
Nov 20, 2008 | Oster 4093-8 Osterizer Classic Blender...
Juicelady blender jar replacement
I have not solved the problem. I just would like FREE information as
to how I can buy a new blender jar. I need the where and the cost.
Why is this so difficult?
Thank you, Lolena
Aug 20, 2008 | Juicelady JL600 Professional Work Top...
Received the Breville Ikon 600 blender as a Christmas present in 2006 and have used it 3 times, with the third time being this past weekend. The product is now out of warranty and low and behold, it...
My IKON 600 Blender fuse had blown. It was located on the circuit board and can be found by removing the bottom of the blender. Fuse is Fast Blow 10A, metric 5mmx20mm. The fuse blew because the bearing in the bse of the jar froze. Bearing # 608-RS. The beraring froze because the seal in the base of the jar was leaking. Solution: Clean seak surfaces, replace bearing and fuse. Total cost of $6 with my labor.
Apr 16, 2008 | Breville CBL10 BlendMaster Classic Work...
Oster 4134 / 4126 Classic Beehive Work Top Blender Logo
222 people viewed this question
Top Oster Blenders Experts
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Oster Blender Expert? Answer questions, earn points and help others
